Another Cam Chain Tensioner Question?
  • renegade_xs11g
    • 462
    • Mid-Michigan
    Yeah, I know it's probably been covered......a lot!
    But, I have a S-L-OOOO-WWW Dial-up connection,
    I can smoke half a cigarette in the time it takes to load the post new thread window, LOL
    it looks like the 'cap' blew out of the end of thd CCT,
    quick fix? jb weld? silicone?
    Thanks, John
    My Photo Bucket
    • 8723
    Yep, just clean the end out good and put a glob of RTV in there, you should be fine.
    • CatatonicBug
      • 6117
      • Clinton, UT
      I bought a new cap at the local bike shop for $5, and added a dab of RTV around the outside edge when I installed it.
      • Ivan
        • Jul 2008
        • 2524
        • Hutchinson KS
        I have one that some one stuffed a oil galley plug in from a V8 engine or something. Looks like a very small freeze plug.
        IIRC, new plugs are still available. I have heard that you can install them with silicone to make them stay put and not seep oil.
        Other option is to shop ebay for a Venture or Vmax tensioner (they will probably come in pairs) which is automatic and a direct bolt in replacement. Its designed in such a way as it won't leak. I posted up a thread about the replacement somewhere on xs11.com. Just be VERY sure you know what you are doing when you put it in, or adjust the cam chain for that matter. It can and will bite you. There are several threads on the issue, and are pretty explicit about what not to do. If you aren't comfortable doing it, find or pay some one who is.
        Ich habe dich nicht gefragt.
        • dbeardslee
          • Nov 2007
          • 4385
          • Maineville, OH
          Do you still have the cap, or did you loose it? I wouldn't put JB Weld in the hole - it comes in handy for checking how much adjustment is left on the tensioner. Lots of members rtv the plug in so it won't leak, but you need the plug. As far as that's concerned, you could probably rtv a suitable sized substitute in. Or if you're not concerned with access, you could always JB Weld a dime to the end of it - guaranteed to improve the value of your bike - by $.10 .
          Jeeze! If you guys type any faster your keyboards are going to burst into flames .
          • renegade_xs11g
            • 462
            • Mid-Michigan
            Thanks,
            I have adjusted the CCT before with no problems, I did my homework first!
            Oh Thank Heaven for Channel Eleven.....
            No the plug is AWOL, I do intend on replacing the unit, but right now the 11 is the only thing I have on wheels except for the Kenworth,
            I'd rather pay for gas in the 11, the KW only gets 6.9 MPH loaded
            I think its around 9, bobtail
            Thanks again, John
            My Photo Bucket
            • CatatonicBug
              • 6117
              • Clinton, UT
              Remind me never to drive behind you - slowpoke!
              • dbeardslee
                • Nov 2007
                • 4385
                • Maineville, OH
                Good catch, Bug . Actually 6.9 sounds pretty darn good. My 379 only got around 5.5 with a load on - less in West Virginia .
                  Smoke about half of one of those "Left handed" ones and you won't care if it EVER loads.. lol.
                  Let me post about 50 high def pics in this thread to show you what you need to do..
                  I remember the dial-up days.. scared to ever click on a pic or video. Nope.. don't miss it a bit!
                  • jmnjrpa
                    • Jun 2009
                    • 863
                    • Lewisville, Texas
                    Dial
                    up? What's that? Some kind of porn site?
                    Original except:
                    Big John
                      • 5057
                      Thanks, John
                      One thing you might check is make sure your crank case breather tibe is not plugged. If it is, it will blow pressure out that plug and could cause other oil leaks also (like the half moon seals and the cam cover gasket).
                      • petejw
                        • 2269
                        • sydney australia
                        jat,
                        id also check the threads on the tensioner
                        havent stripped, if the plunger has moved it
                        could pop out that plug.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        1981 xs1100 RH (aus) (5N5)
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                        • renegade_xs11g
                          • 462
                          • Mid-Michigan
                          You Folks never cease to amaze me!
                          Skids: I hadn't given the Breather a thought until I saw your post....
                          Cam Plugs are seeping a little....wouldn't think, but I'll check....
                          Pete: I don't think they have, but I'll check those too
                          Hey, how you been, haven't 'talked' to you in a while...
                          Bug: that was a good catch, obviously need to proof read better
                          slowpoke was my cb handle when I first started driving truck...
                          brick on the fuel pedal, downhill w/full load in trailer 62 MPH max speed
                          DB: my fuel milage will get to 'round 7.4... if it ever stays above 50 degrees. LOL
                          TOD: I smoke with both right and LEFT hands, 'nuf said
                          50 Hi-Res pics, ouch!!!!!!!
                          jr: porn, ha....I loaded that dyno test from 'you tube' someone linked....
                          3.5 min video......4 HOURS to load......my phone almost melted!
                          Thanks again everyone
                          My Photo Bucket
