heal toe shifter
  • #16
    Something along these lines,think it might work?
    '80 XS1100 SG
    • #17
      Heel-toe shifter questions come up on a regular basis. There were kits made for the XS; once in a great wile these come up on eBay or a member sells a set. Advantage is these are bolt-on kits.
      Others have made some nice looking home-brew devices but you have to be something of a fabricator to duplicate them
      I put a Honda 90 heel-toe shifter on my XJ; splines and everything fit with no modifications. Added floorboards as well but mounted them below stock position to get a better angle on the knee. Used a set made for HD with a male mounting post; fit into the XJ's stock mounts after I ground out the rivet that held the stock pegs in place. (Added a washer to both sides of the post.) I got the set on eBay - many years ago! - for a reasonable price. New sets are still available. This style is adjustable for height as well as forward - back placement. They will flip up just like the stock set if you lay the bike down. In my case, since I mounted them lower than stock, it cost some ground clearance.
      Poor man's heel-toes shifter and floorboard! Note the shifter is angled down from horizontal - hard to tell in photo - but allowed less foot movement to shift. One other comment is that this shifter is a bit long; if I was going to do it again I would cut the heel pad off and move it forward abut 1/2 - 3/4 inch but that really depends on each rider's geometries.
      Not the same as forward controls but this approach may be an option for some.
      Right-side floorboard required a bit of work to get it to fit outside the brake pedal. I don't recall this was a big deal but I do remember it had to be done.
      Both sides are angled down just a bit to give the boards a more natural "feel" when riding. It took a bit of trial and error to come up with the best settings but it was worth it in the end.
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
      • #18
        Thanks Jerry...I think that is about what I need.I am having problems up shifting and need to move my whole leg but down shifting is not so bad.
        I need to give this some more thought
        But I think you guys have put me on the right track for now
        '80 XS1100 SG
        • #19
          I have two here
          With floor boards and for ward controls. MO if you need them PM me.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
