so i had a brain fart
i removed the ronge screw not the drain plug lol but the one on the back upperside dint see the one becuase its behind the oil filter, and i 4-1 exuahst.
well i fired her up in 1st gear and she ran so i backed her out and gave it a test run she ran in first then started to rattle, so hit 2nd and went a little and rattled so i hit 3 and 4 and was slugish but ran.
so i went home pulled into the garage, onre thing i tried to ajust the cluch down at the trans and i have to screw it in about 3/4 otherwise my cable is to loose and i have no clutch?
well i desided to remove cover again and drain all oil thats were iam at now./
also it has a hard time shifting into any gear when not running?
i guess the bike hasnt been fired in 10 years. so iam tring to figure out if what to do next?
i decided at least i would remove basket and mic the springs and plates and soak them in oil. here is were i am trying to decide if its just the cluch from sitting so longe? or the 1st 2nd deal also the tab for the basket bolt has been messed with and the fact the the bike has a home made gasket for the crankcase means someone has been in there to do what i dont no?
would you soak the parts mic the spings and disks repace with heavy duty springs then reinstall and see if it works or flip the bike and do the gear fix?
ps:the bike is hard to push with clutch in or out
