xj1100 clutch trans update
  • jmcmillan40
    • Apr 2010
    • 68
    ok trans gear pictures with lables help
    ok it looks like rub marks on 1st gear
    2nd gear to 1st look rounded
    5th looks round like it should be
    4th looks rounded like it should be
    3rd to 2nd ?
    what do you think
    also get this there was only one clip on the shifter shaft the inner one was missing and ther was a washer ? dint see a washer in the fix
    and ther outer c clip was missing on the outside of ther oil pump gear on ther other side of shifter shaft inner one is there
    also i dint have a return sping on the clutch cable arm?
    seems like someone was in here that dint no what they were doing
    does it look
    • jmcmillan40
      • Apr 2010
      • 68
      ok real pictures trans gears what do you think? xj1100
      ok it looks like some rub marks on 1st gear?
      2nd gear dogs to 1st gear ther corners look rounded?
      2nd gear dogs to 3rd gear slots look rounded like they should be?
      3rd gear slots to 2nds gear dogs look rounded like they should be with some rub wear and sleight corner ware?
      5th gear dogs to 4th gear slots look rounded like they should be sleight rub ware?
      4th gear slots to 5th gear dogs looks rounded like it should be with minimal ware?
      5th gear dogs to 4th gear slots look rounded like they are suppost to be?
      thats if iam correct in gears
      tell me what you think and what should i do?
      thanks
      also get this there was only one clip on the shifter shaft, the inner one was missing and ther was a washer ? dint see a washer in the fix
      and ther outer c clip was missing on the outside of ther oil pump gear on ther other side of shifter, shaft inner one is there shouldnt there be 2 c clips one inner and one outer on both sides of the shifter rod?
      also i dint have a return sping on the clutch cable arm? saw one in the clutch ajustment fix?
      and i could never get the gear to shif past 1st and nutral wile sitting when i test drove it 1st 2nd rattled and slipt out but i did get it into 3rd 4th and it ran no rattle?
        The service manual, if you don't have one, has the exploded view and description of each gear, washers, clips, etc. and can be downloaded from any one of CatonicBug's posts. It's best to refurbish all the dogs and slots on all the gears on the countershaft while you're in there. If you do it now, you probably won't have to go in there for a long while.
        • jmcmillan40
          • Apr 2010
          • 68
          is this right
          do i have it right 1st pic is 1st gear
          2nd pic is 2nd gear to 1st with bad dogs
          3rd pic is 2nd gear with dogs going to 3rd gear slot
          4th pic is 5th gear going to 4th gear slots
          5th pic is 3rd gear slots going to 2nd dogs
          6th pic is 4th gear slots gouing to 5th gear dogs
          • jmcmillan40
            • Apr 2010
            • 68
            ok i messed up sorry i think this is right gear order
            [QUOTE=jmcmillan40;274808]
            ok i messed up
            1st pic is 1st gear and looks like rub marks and ware?
            2nd pic is 4th gear dogs goiung to 1st gear and dogs looked rounded on corners?
            3rd pick is 4th gear and dogs going to 3rd gear and look good?
            4th pic is 5th gear dogs going to second they look ok to me?
            5th pic is 2nd gear slots going to 5th dogs and the slots look like they have rub and ware
            6th pic is 3rd gear going to 4th gear dogs looks like minimal ware on slots
            that right?
            • jmcmillan40
              • Apr 2010
              • 68
              trans gear help
              [quote=jmcmillan40;274808]
              ok i messed up
              that right?
