Carb tower O-rings
    Carb tower O-rings
    Would anyone have any extra teeny-tiny(official tech-term) O-rings....the ones that go in the idle mix screw towers on the later 81 carbs? If someone knows the actual size, think I can get them at the local bearing house. Got one that is in two pieces, but has stayed in place so far. Just soon replace all four so as to eliminate any idle/midrange issue that may show up. Plan on pulling carb bank and re-set floats as running level is dern near 1/2" down from bottom of carb body. That was "my bad"......got my MM's and 32nds confused or just went brain-dead somewhere during process. Just wanna get those levels corrected somewhere between the sea-level settings and mile-high, sea-level being 3/16" below carb body housing running and the way too low 28mm float level they now are. Would hate to toast it at Caly Rally in June......eek.
  • tw1980
    • Apr 2009
    • 662
    • Bend OR
    I got some o rings for mine at ace hardware store.They have bunches of them.Make sure they fit around the needle valve and the od is not larger than the spring.So they wont get stuck in the hole. Terry
    1980 special (Phyllis)
    1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
    • Yahman
      • Mar 2008
      • 779
      • Salem, OR
      You want to make sure that the O-rings you use are made of a material that will survive in that environment, something like Viton O-rings. I have several of the proper ones for your carbs, PM me with your address and I'll get you fixed up with some.
      Larry
      82 XJ1100
      80 XS1100G (Project bike)
      64 Yamaha YA-6
      77 Suzuki TS-185
        Yahman, PM sent.
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          I bought mine from Lowe's in the faucet repair section. Got a box of 20 for less than $3. The teeny tiny orings around the mixture screws, that is.
          Ich habe dich nicht gefragt.
            Hi Motoman,
            Are these what you are looking for?
            These are Metric
            Neoprene is good for gasoline.
            • Yahman
              • Mar 2008
              • 779
              • Salem, OR
              Originally posted by motoman
              Yahman, PM sent.
              They are in the mail, you should have them soon.
              Larry
              82 XJ1100
              64 Yamaha YA-6
              77 Suzuki TS-185
                Yes, those teeny-tiny(official XS tech-term)ones. Thanks, think Yahman gots me covered.
                  Hi Motoman,
                  OK that is good. I have a few sets if anyone needs them.
                    Got them today Yahman.....Thanks. Check your PM again.
