Would anyone have any extra teeny-tiny(official tech-term) O-rings....the ones that go in the idle mix screw towers on the later 81 carbs? If someone knows the actual size, think I can get them at the local bearing house. Got one that is in two pieces, but has stayed in place so far. Just soon replace all four so as to eliminate any idle/midrange issue that may show up. Plan on pulling carb bank and re-set floats as running level is dern near 1/2" down from bottom of carb body. That was "my bad"......got my MM's and 32nds confused or just went brain-dead somewhere during process. Just wanna get those levels corrected somewhere between the sea-level settings and mile-high, sea-level being 3/16" below carb body housing running and the way too low 28mm float level they now are. Would hate to toast it at Caly Rally in June......eek.
Carb tower O-rings
Carb tower O-rings
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Tags: None -
I got some o rings for mine at ace hardware store.They have bunches of them.Make sure they fit around the needle valve and the od is not larger than the spring.So they wont get stuck in the hole. Terry1980 special (Phyllis)
1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod -
You want to make sure that the O-rings you use are made of a material that will survive in that environment, something like Viton O-rings. I have several of the proper ones for your carbs, PM me with your address and I'll get you fixed up with some.
LarryInventor of the YICS Eliminator. Want one? Get it here.
82 XJ1100
80 XS1100G (Project bike)
64 Yamaha YA-6
77 Suzuki TS-185
See it here... http://www.youtube.com/watch?v=cBYT4C9_6AcComment
Yahman, PM sent.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
82 XJ1100
64 Yamaha YA-6
77 Suzuki TS-185
Yes, those teeny-tiny(official XS tech-term)ones. Thanks, think Yahman gots me covered.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Got them today Yahman.....Thanks. Check your PM again.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
