Step one
  • mack
    • 2411
    • Ontario, Canada
    Step one
    Well I'm ready to start putting "Hermes" back together. Still waiting on some parts but tommorrow the motor goes back in the frame.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • GARTHXS
    • 1631
    • Seattle
    Wow!!!
    must be nice to have a new bike!
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      Although I like to see them whole, your looks nice even on the wall, keep us posted. What are you painting the tank and side covers, any powder coating? Show us more!
      Just saw the tank, going for the back and chrome look...me like. Any mods or you staying original?
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
      • cywelchjr
        XS-XJ Super Guru(Deceased)
        • 4450
        • Sacramento, CA
        I have to say that organization like that, done so well, is a clear sign of a sick mind! I wish I had two so I could do that to one of them while still riding the other, the switch, how sweet would that be?
        • psycoreefer
          • Feb 2008
          • 1557
          • Minden, NV
          looks good, to bad your missing pieces
          I don't see the final drive or the sissy bar that goes with that luggage rack.
          Bikes going to look awesome when your done.
          1979 xs1100 Special -
          My Bike:
          [link is broken]
          • tinman905
            • Aug 2007
            • 946
            • Orangeville,Ontario ,Canada
            What's your plan for sliding the engine into the frame?
            BDF Special
            • mack
              • 2411
              • Ontario, Canada
              Paint
              All the painted pieces were ground down to bare metal to remove the rust. Still had a lot of pitting in it so I sent it all out to a painter. He went missing and it freaked me out as you can see he had most of my bike. Anyway I found him and I think he did a great job. 2 coats of epoxy filled the pitting, 2 coats of high gloss black, 3 coats of clear. The tank was cleaned and lined, the seams were glass welded and it passed the pressure test. I was able to copy the gold flake content from under the decals in the side cover's so the tank and side covers are very close to what they were 30 years ago. You can't see the gold unless it's in sunlight.
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
              • mack
                • 2411
                • Ontario, Canada
                motor
                James:
                I've got a couple friends coming over tommorrow AM, and well just lift and set it in. Only take a couple minutes. I finished installing the clutch, motor mounts and cleaned all the electrical connections on the motor today. I'll get up early and put a coat of past wax on the hard t0 get at places before we drop it in.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                • freak_leg
                  • Aug 2009
                  • 152
                  • Lakeville, Minnesota
                  My hat is off to you sir. Your pictures almost brought a tear to my eye. I'm hoping to start a similar parts pile this winter
                  Tony
                  78 xs11 aftermarket 4-2 HD mufflers, whats left of it is stock. A work in progress for sure.
                  • Big Daddy Funk
                    • 639
                    • Brantford, Ontario, Canada.
                    Bravo !!! Another XS 1100 addiction
                    Well done Mack, How many hours did you spend getting to step one?You are truly hooked now.
                    Rick
                    I May Be Crazy, But I Have A Good Time.
                    Northern Gypsy - 2010 Kawasaki Concours 14 ABS - Daily rider
                    • mack
                      • 2411
                      • Ontario, Canada
                      addiction
                      You know I finally get it. I couldn't figure out why so many had more than one bike. Now I understand. After the motor was in I was just vibrating and wanted to put it all together in one day. It's taking every bit of will power for me to just take my time and do the final cleaning and assembly of all the little pieces, and putting it together in the proper order. Still waiting for new coils, another five weeks (what the f...k), I should never have special ordered the black accel's, carb parts and valve springs, but nothing major that will keep me from assembly.
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
