To my surprise, the kit I bought worked perfectly with my RLU! High worked, low worked, the high beam indicator worked, it changed from high to low exactly like it did before (just the light was a LOT brighter!). That put me a bit of a quandary because if I kept the RLU, then I wouldn't have to modify the wiring at all. But, I WOULD have to find a new home for the ballast.
What I figured happens here is that The HID draws a lot of power when first lit up ( it does have a 30 or 40 amp fuse in its harness for a reason) and still draws a fair bit until normal operating temperatures are reached when the current draw tails off. That would explain why the RLU didn't play up initially. Only after about 10 minutes on the road did it make its presence felt.
BTW, a tip if your HID quits while on the road. Hasn't happened to me, but I've thought about the event, just in case. Carry a H4 bulb as a spare. In an emergency, pull the fuse from the HID harness, unplug the 3 pronged headlight connector from the harness and connect it to the H4 bulb you've just refitted in the headlight bucket and it'll work as normal to get you home without having to rip any bits out.
