As part of my "get the bike ready for school" project (on going), I have FINALLY replaced the headlight on my 79F. I was fairly tired of being able to outrun the light at about 35 mph... I knew I could do a LOT to improve it with a good Silver Star bulb and a lot of cleaning/reworking of the wiring harness. But, with the greatly decreased price of HID kits and the high price of the Silver Star bulbs, it was a pretty easy decision to go HID.
My original plan was to get rid of all the connectors that were not needed (aka: splice into the original harness with wiring as neat and short as possible). As I started to test fit everything, I found that with the lengths of the components, everything pretty well fell into place. The small ballast took the place of the RLU, the head light wiring was rerouted and was the perfect length to reach, etc. The only actual "modification" I made to the kit was to lose the inline fuse and use one of the spare fuse locations on my new fuse block. It turned out to be a very nice and neat install that actually went faster than I expected.
During all this, I DID find two things that definitely contribute to the low light output. The first one is probably the biggest. For some reason, Yamaha made the harness to the headlight with two connections. There is the normal headlight connector at the end, but that is on a short (3" long or so) stub harness that had another connector that connects to the main harness with spade connectors.
The headlight plug was almost perfect. Clean. Shinny. Beautiful. The spade connectors made up for it! So, I pulled each pin out and hit it with a polishing wheel in my Dremel until they were nice and shiny. Of course, the power for the headlight no longer goes through this connector, but still!
The second issue is that the PO REALLY crashed this bike! I knew it had been crashed before I bought it back in '89. The tank had been repaired and repainted, same for the side covers. The right side turn signal stalks where both bent, there was some pretty good scrapping on the right side skid bars, etc.
What I DIDN'T know was just how out of square the head light housing and trim ring are! It's one of those things that you know it wasn't 100% right with it installed, but once I pulled the headlight out and actually looked at the trim ring, it was completely trapezoidal in shape. I would guess it is out by at least 1/4" and probably closer to 3/8"! When I put the bare ring up against the headlight bucket, it fit perfectly, so there is no doubt the bucket is also tweaked. Time to start looking on eBay I guess.
One of the surprising things was just how CLEAN the headlight housing and bulbs where. The bulb looked like it was brand new. It was shiny and perfect with NO corrosion on it at all. Heck, even bulb itself looked perfectly clear. The inside of the housing was also pretty much perfect. It was very clean and the silver coating did not have any issues at all. Part of that was because the rubber dust seal was also in almost perfect condition. Soft and flexible and still in the correct place. Definitely NOT what I expected to see.
After seeing how clean the inside of the housing was, I knew all the "dirt" had to be on the outside of the lens. I had cleaned it several times with soap and water, but it never got the brown film off, so I assumed it had to be inside. This time, I hit it with engine cleaner and let it soak for about five minutes. When I wiped it off, I had nice, shiny and clear glass again. Definitely a huge improvement!
Performance wise, what can I say? Night and day doesn't quite cover it! I won't be able to just leave it on high beam all the time now. I also love the WHITE light (6500k bulb). That was one area I was always jealous of HID lights. No matter how good a halogen light was, it always had a yellow tint to it, especially when set against a HID light. Yes, even the Silver Stars...
All in all, this is definitely one upgrade I can recommend to anyone that rides at night. The factory lights didn't really cut it when the bikes were new and 30 years time hasn't help them. Thankfully, technology HAS improved and we can rebuild it and make it better than ever!
