molybdenum disulphide paste
  • mack
    • 2411
    • Ontario, Canada
    My manual says to put this on the valve stems. Can someone educate me on what it is and does. I thought the cavity under the lifters was flooded with oil, or are we just talking about the lower portion of the stem that moves in and out of the combustion chamber?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • randy
    • Dec 2003
    • 4521
    It's the stem they're talking about. A little on the whole stem, not enogh to drip. Use engine oil, or if you're paranoid pick up a bottle of engine assembly pre-lube. Melling, Permatex and a few others make it.
    • dbeardslee
      • Nov 2007
      • 4385
      • Maineville, OH
      Molybdenum disulfide bonds with metal, so even after the grease component has dried up it still provides lubrication. This is also the stuff you want to use on your drive shaft splines every 10k miles. Moly paste has a higher moly content than moly grease, and the more moly the better. Permatex makes a moly paste that's 60% moly - compared to 3% in most moly 'fortified' grease. It comes in an 8 oz container, with a little brush attached to the top - comes in real handy when it comes to getting the paste on the part instead of yourself. Here's a link to the good stuff.
      • tinman905
        • Aug 2007
        • 946
        • Orangeville,Ontario ,Canada
        I have tried for ever to find moly paste here in Canada . No one carries any moly paste just the grease and no dealer in the US will ship it to Canada.
        BDF Special
        • Geezer
          • May 2003
          • 2985
          • Willamina, Oregon 97229
          Let me know where to find it and I'll add it as an option to the group valve buy.
          BTW, I've only used the usual assembly lube when putting a head together or a little oil when I don't have that...
          Geezer
            Moly 60 paste can be had at the Honda dealer too. Use it on the splines of my ST1100 and of course on the Yammy splines.
              Hi Tinman,
              that link is to a Loctite product. NAPA stores sell most of the Loctite product line, have you tried there?
              • dbeardslee
                • Nov 2007
                • 4385
                • Maineville, OH
                If you follow the previous link, it will take you to one outfit that sells the moly paste. Reliable Paper has it at a cheaper per unit price, but there's a minimum order of 4. I don't know if either ships to Canada.
                • tinman905
                  • Aug 2007
                  • 946
                  Yes I have tried a few Napa store around my area. Neither of the two store I have tried knew what I wanted and have never seen it before .They try to sell that gold synthetic grease saying it the same stuff. I am in no rush to find it until then I will use the moly grease I have. Thanks anyway.
                  Hi Tinman,
                  BDF Special
                  • dbeardslee
                    • Nov 2007
                    • 4385
                    • Maineville, OH
                    Sorry about that - should have said loctite. I must have permatex on the brain.
                    • ManitoulinLad
                      • 358
                      • Manitoulin Island,Ont.,Canada this is in Lake Huron
                      Hey Guys - I printed off the example of the product from the link & walked it over to my local independant auto parts supply store across the street - it has the loctite part# on it - he looked it up & he can get it buts its $52.00 CDN for the 8oz. container. I think I'll stick to my regular moly grease I get off from him. So it is obtainable just a tad pricey - Dan
                      '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
                      1179 big bore kit, 80SG motor
                      Rebuilt head, valves
                      TC Bros Forward Controls (Brass Pegs)
                      Tkat Fork Brace
                      T.C. Spade Fuse Box
                      Dyna Coils & wires
                      Mikesxs shocks,controls,& bars (special)
                      ISO grips with stelleto ends
                      4 into 1 black Bassani exhaust
                      Bridgestone Spitfires
                      Tuned by Tinman905
                      & a will to keep it.
                      • mack
                        • 2411
                        • Ontario, Canada
                        bulk order
                        My sister in law lives in Ohio, she's coming up first week of April to lecture at the College here. Send me a PM and I'll have her bring up extra.
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
                        • tinman905
                          • Aug 2007
                          • 946
                          I just found a can , Gord Davenports auto parts has a supplier in Barrie and they will have it tomorrow for me. But it's $36.00 .
                          BDF Special
                          • WMarshy
                            • Apr 2009
                            • 2402
                            • Mexico NY
                            Check here, seems reasonable for US customers...
                            JD Industrial Supply is a trusted distributor of industrial supplies, offering essential products, maintenance solutions, and reliable equipment for a wide range of applications.
                            or
                            ...about a $1 an Oz.
                            '79 XS11 F
                            Stock except K&N
                            '79 XS11 SF
                            Stock, no title.
                            '84 Chevy K-10 "Big Blue"
                            • Geezer
                              • May 2003
                              • 2985
                              I just checked my gun stuff and my bullet mold release spray is an aerosol
                              molybdenum coating. It's around 8 bucks a can from Midway Arms. For those that buy valves in the group buy, I'll spray the stems on request...
                              Geezer
