My manual says to put this on the valve stems. Can someone educate me on what it is and does. I thought the cavity under the lifters was flooded with oil, or are we just talking about the lower portion of the stem that moves in and out of the combustion chamber?
molybdenum disulphide paste
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
Molybdenum disulfide bonds with metal, so even after the grease component has dried up it still provides lubrication. This is also the stuff you want to use on your drive shaft splines every 10k miles. Moly paste has a higher moly content than moly grease, and the more moly the better. Permatex makes a moly paste that's 60% moly - compared to 3% in most moly 'fortified' grease. It comes in an 8 oz container, with a little brush attached to the top - comes in real handy when it comes to getting the paste on the part instead of yourself. Here's a link to the good stuff.I think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
I have tried for ever to find moly paste here in Canada . No one carries any moly paste just the grease and no dealer in the US will ship it to Canada.Molybdenum disulfide bonds with metal, so even after the grease component has dried up it still provides lubrication. This is also the stuff you want to use on your drive shaft splines every 10k miles. Moly paste has a higher moly content than moly grease, and the more moly the better. Permatex makes a moly paste that's 60% moly - compared to 3% in most moly 'fortified' grease. It comes in an 8 oz container, with a little brush attached to the top - comes in real handy when it comes to getting the paste on the part instead of yourself. Here's a link to the good stuff.BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
Let me know where to find it and I'll add it as an option to the group valve buy.
BTW, I've only used the usual assembly lube when putting a head together or a little oil when I don't have that...
GeezerHi my name is Tony and I'm a bikeoholic.
The old gray biker ain't what he used to be.Comment
Moly 60 paste can be had at the Honda dealer too. Use it on the splines of my ST1100 and of course on the Yammy splines.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Hi Tinman,
that link is to a Loctite product. NAPA stores sell most of the Loctite product line, have you tried there?Fred Hill, S'toon
"The Flying Pumpkin"Comment
If you follow the previous link, it will take you to one outfit that sells the moly paste. Reliable Paper has it at a cheaper per unit price, but there's a minimum order of 4. I don't know if either ships to Canada.Let me know where to find it and I'll add it as an option to the group valve buy.Last edited by dbeardslee; 03-17-2010, 12:06 PM.I think I have a loose screw behind the handlebars.
Yes I have tried a few Napa store around my area. Neither of the two store I have tried knew what I wanted and have never seen it before .They try to sell that gold synthetic grease saying it the same stuff. I am in no rush to find it until then I will use the moly grease I have. Thanks anyway.BDF Special
Sorry about that - should have said loctite. I must have permatex on the brain.that link is to a Loctite productI think I have a loose screw behind the handlebars.
Hey Guys - I printed off the example of the product from the link & walked it over to my local independant auto parts supply store across the street - it has the loctite part# on it - he looked it up & he can get it buts its $52.00 CDN for the 8oz. container. I think I'll stick to my regular moly grease I get off from him. So it is obtainable just a tad pricey - Dan'81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
1179 big bore kit, 80SG motor
Rebuilt head, valves
TC Bros Forward Controls (Brass Pegs)
Tkat Fork Brace
T.C. Spade Fuse Box
Dyna Coils & wires
Mikesxs shocks,controls,& bars (special)
ISO grips with stelleto ends
4 into 1 black Bassani exhaust
Bridgestone Spitfires
Tuned by Tinman905
& a will to keep it.Comment
bulk order
My sister in law lives in Ohio, she's coming up first week of April to lecture at the College here. Send me a PM and I'll have her bring up extra.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
I just found a can , Gord Davenports auto parts has a supplier in Barrie and they will have it tomorrow for me. But it's $36.00 .BDF Special
'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
I just checked my gun stuff and my bullet mold release spray is an aerosol
molybdenum coating. It's around 8 bucks a can from Midway Arms. For those that buy valves in the group buy, I'll spray the stems on request...
