I know this doesn't help you now. I made a drill guide that fits in the threaded hole and then use a stock size drill that will drill out the tip and stay on center. So if anybody needs to drill out any tips, pay for shipping and you can use it.
Broken idle mixture screws!!! HELP
Originally posted by garthxs View PostFor drilled out idle mix holes, maybe drill it out a little and replace with a conical plug with a stock size hole, any ideas out there
If the material is thick enough you might be able to trim off the metered part of a pilot jet, then drill out the carb idle hole and press the metered part of the pilot jet into the new hole.
It'd have to be centered pretty much dead on or the idle screw tip would touch one side or another of the 'new' idle mix hole and it wouldn't meter properly. If it's far enough off centerline it could break off the tip in the hole again and you'd be pretty much screwed, again.
Good thinking, Garth!
Regards,
Scott-- Scott
Originally posted by garthxs View Post... what about that micro laser welding they were talking about in the float post thread ...
If you have your own laser that's a different story, amigo, and I have a set of '79 carbs that got hammered when someone drilled out some broken idle scre....
Regards,
Scott-- Scott
proper size hole? ??
I'd bet it's not just a "proper size hole" but a specially designed tappered bit was used to create the passage for fuel/air.
mro
(I know what I said, but do you know what I mean??? )
