Kerker 4into1 95$ A good deal???
  • Psychedelic_Max
    No Longer Xsive=sold
    • Nov 2009
    • 40
    • Quebec, Canada
    I was looking for a 4into1 for cheap and I found this (see photos) and it's 95$ + shipping. Does it worth it? Will it be possible to fix the dent?
    What would tou do???
    SEE PHOTOS HERE
    Thanks!
    Although they look rough, they look solid. You can pull the dents if needed, but doubt you'll notice the difference without a dyno. Clean them up and high temp black paint.. or better yet, find someone with big enough oven, and high temp black powder coat, and they would look pretty sharp.
    Those are getting hard to find, so even if you decide to not use them, I think you can clean them up a bit and easily get your money back on them.
    • barberad
      • 416
      • the 45th state
      $95 canadian? That's like $200 american right now, isn't it? The pipes will clean up various ways, sandblast, paint, powdercoat, ect. The dents will probably match quite a few of the bikes on this site. (Well... atleast mine.)
      Get 'em If you want 'em and if not, share the link with someone else that would.
      Dan
      Current Rides: '82 XJ w/Jardine 4-1's, GIVI flyscreen, '97 Triumph Trophy 1200
      Former Rides: '71 CB350, '78 400 Hawk, '75 CB550/4;
      while in Japan: '86 KLR250, '86 VT250Z, '86 XL600R, '82 CB450(Hawk II), '96 750 Nighthawk, '96 BMW F650
      • Yard Dogg
        • Mar 2010
        • 884
        • Tri-Cities, Wa
        Whats up. If your gonna buy those pipes then realize those dents are not easily removed by your average back yard mechanic. It seems easy, sounds easy, but is a real pain in the behind without having a metal shop. If your a descent welder/steel worker fine. I had to straighten out a dirt bike pipe and it blew me away. I have a wire feed welder and I admit I'm not the greatest but I'm not terrible either. I tried freezing them with ice to pop the dent out, pumped em full of air and heated the dent, nothing. I ended up having to cut the pipe apart and make an expansion tool to round it out from the inside then weld em back together. It's an ugly hack job, but it works!
        From that experience I think I'll stay away from pipes that are bent. You should look around a bit longer. I think you can get a better deal from someone on here.
        • boediddly
          • Dec 2009
          • 50
          • columbus,oh
          Junkyard pipes
          I have to disagree,with those pipes. I found a set of mac 4-2 at the old bike barn that were almost immaculatefor 130$, and have seen one kerker on craigslist for 100$ brand new.If you take your time and look around i think youll find something better.
            A dirt bike pipe is probably several times thinner metal than the steel on these. Just like pulling dents on a car, you could take it to a body shop, have a couple studs tack welded to the spot and pull them out for next to nothing. They won't be perfect, but if you just had to have it pulled out, you can. The one down side I see to this, is if the Kerker is a single or double walled pipe?
            A MAC for $130.. is about right since it's only a little more than double that new. You'll get much better performance out of the Kerker though. If you find a Kerker new, or ANYTHING new for $100 on Craigslist that fits these bikes I suggest you buy it.
            • Yard Dogg
              • Mar 2010
              • 884
              • Tri-Cities, Wa
              Yeah there are shops that can pull those dents and make em nice but after purchase price, paying to pull the dents and time and effort recoating your into those pipes for too much. I tend to be impatient and get into that stuff and take it from me, don't do it. Patience pays.
              • barberad
                • 416
                • the 45th state
                Yes, but there are only a handful of people on this website that would take the time to go over every square inch, oh wait your in Canada, square centimeter of your bike and then give you sh_t because there is a dent in your headers. The choice is yours, but IMO, Kerkers are good pipes.
                Dan
                • Yard Dogg
                  • Mar 2010
                  • 884
                  • Tri-Cities, Wa
                  Just offering some advice. I wouldn't give him crap for having dented pipes, but they are not on his bike yet, so why put em on if he can get a better deal?
                  • Psychedelic_Max
                    • Nov 2009
                    • 40
                    • Quebec, Canada
                    Dan
                    ahahah! Square centimeters!:P I'm a mechanic and I don't use any metric mesures. But that was funny.
                    If you guys don't think I would see any difference without a dyno I will buy it. I was thinking about wrapping it anyway with some exhaust wrap so it won'T show the dents. But I was also thinking about heating the dents to remove the chrome. then solder a nut on it and use a ''reverse hammer'' to pull the dents out. I have the ressources to fix it.
                    And I was wondering in headers spray paint works well on chrome or I would have to remove it all.
                    • 79xs1100s
                      • Aug 2009
                      • 115
                      my Kerker set has worse dents and affects power on my 79 special in no way what so ever. Great pipes
                      XS11.Com resident Black Sheep
                        un-denting a pipe
                        Originally posted by Yard Dogg
                        Whats up. If your gonna buy those pipes then realize those dents are not easily removed by your average back yard mechanic. It seems easy, sounds easy, but is a real pain in the behind without having a metal shop. If your a descent welder/steel worker fine. I had to straighten out a dirt bike pipe and it blew me away. I have a wire feed welder and I admit I'm not the greatest but I'm not terrible either. I tried freezing them with ice to pop the dent out, pumped em full of air and heated the dent, nothing. I ended up having to cut the pipe apart and make an expansion tool to round it out from the inside then weld em back together. It's an ugly hack job, but it works! - - -
                        Hi Dogg,
                        here's how. Turn up a steel egg that slips inside the pipe with a tapped hole in it.
                        (OK,to make this part you did need a "bro with lathe", the rest is just blacksmithing.)
                        Thread an eyebolt into the egg.
                        Attach a chain to the eyebolt.
                        Drop this into the pipe, have the chain just long enough to reach the other end.
                        Make a long eyebolt from threaded rod and attach it to the chain.
                        Slip a length of waterpipe over the long eyebolt so that it rests against the end of the pipe, a washer between may be needed. Put a thick washer at the other end of the pipe, spin a nut onto the long eyebolt, double-nut the very end and start wrenching the nut around to tension the chain.
                        When the egg hits the dent, take a torch to the dent and keep wrenching so the egg smears the dent back round again.
                        • Yard Dogg
                          • Mar 2010
                          • 884
                          • Tri-Cities, Wa
                          Thats a nice trick. I considered something similar too that for the small bend section of my dirt bike pipe but those are just too weirdly shaped. If I ever have to straighten my pipes out on the XS though, now I know how.
                            • 8962
                            Yes, it worked fine for me. Scuff the chrome first, no going back though.
                              Fred's idea wouldn't work if the Kerker is a double walled pipe. You couldn't get the metal on the 2nd layer hot enough. If it is, then even my idea of tack welding a rod to pull the dent out would leave the underlying 2nd layer still dented. It would help it cosmetically, but not functionally.
