Pretty glowing reviews, and don't seem to have the messy/complicated set-up that the RaceTech emulators have. A bit pricey, and no specific application for the XS, but 'adapting' is part of owning one of these bikes, right?
'78E original owner
For some reason I thought I saw another post here for this or something similar. I cant seem to find it now. Price was not as bad.
1980 XS 1100SG
Dyna 3 Ohm Hi Output Coils
Pod Filters
DynoJet Kit
T.C.'s Fuse Block
V-Max Auto CCT
Anybody want to design a set for the 11?
I have access to a CNC lathe now that would cut the cost considerably
I saw Math H's post on the UK site for the YSS brand valves. I know they were for different forks, but I don't see why we can't come up with with an XS design. Anodizing increases cost and I don't see the need for it when it is emersed in fork oil.
MDRNF
79F.....Not Stock
Anodizing would only be needed for wear in this application, and I don't see where there would be much wear.
If anyone has a set of emulators that arent' installed, some measurements would be all that's needed to come up with a good enough program for the lathe, especially if the controller has decent conversational programming...
If anyone has a set of emulators that aren't installed, some measurements would be all that's needed to come up with a good enough program for the lathe, especially if the controller has decent conversational programming...
I've got a set if somebody wants to do this; mine are for 39mm forks, but an adjustment of the overall diameter should be all that's needed. The only trick would be coming up with the right spring to control the valve.
I posted this originally because these are the only ones I've seen that claim to offer both compression and rebound control as well as being able to tell if it's wheel or frame movement. They do have a patent, so I'm sure that's one reason why the cost is high...
'78E original owner
Let me dig them out and take a few pics of them. These aren't XS11-specific units, but are for 39mm forks. But the 'working' part is identical, so you just have to 'adjust' the diameter and maybe how they 'seat' in the damper rod.
'78E original owner
Add in the fact that you should replace the springs to get full benefit of the emulators (another $100) and the 'Intiminators' (which I linked to and use OEM springs) don't look so expensive now. But they aren't offering a XS11-specific version, so this means either passing on them or possibly modding something they do sell to fit.
And to be clear, what I have that XSChop and Yahman are interested in copying are emulators, not 'Intiminators'; still interested?
'78E original owner
