78e carbs not fueling 3-4
  • petejw
    • 2269
    • sydney australia
    k, if its been sitting for a while,
    how were the carbs in general when you pulled them apart?
    was fuel left in it? if they were pretty gummed up they might
    need a good soaking in carb cleaner. (all rubbers would have to be removed)
    with the bike running, adjusting the mixtures screws on 3 and 4 does it make any difference to the engine?
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • MrWheelie
      • Dec 2007
      • 92
      • Dallas Texas
      carbs were really clean, just the pilots were a little clogged, when the bike is running you can look inside the carb and see its not fueling, no the adjustments didnt help
      1978 XS-Eleven
      • petejw
        • 2269
        • sydney australia
        k, sorry for all the questions
        sounds like the bike isnt with you,
        when you can try starting the bike on the choke,
        the choke system uses a different fuel circuit to deliver the fuel,
        if it fires on all 4 then that would confirm blockages in the pilot circuit.
        To clean the pilot circuit, removing the pilot jet
        along with the air jet at the back of the carb, leave the mixture screw in
        but screwed out a fair way, block the pilot jet with your finger and spray carb
        cleaner thru the air jet, you should then be getting carb cleaner out of the holes(4) from that area near the inside of the butterfly.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • MrWheelie
          • Dec 2007
          • 92
          • Dallas Texas
          #34
          everything is good but the 2 left carbs, I moved the good carbs over to the left 2 intakes and they fuel, something isnt right in the carbs, anybody have a good set of carbs for sale?
          1978 XS-Eleven
          • XSokieSPECIAL
            • Jun 2009
            • 1631
            • Tulsa, OK
            #35
            How the hell did you do that?
            • MrWheelie
              • Dec 2007
              • 92
              • Dallas Texas
              #36
              bowls were full, I mounted the 2 right carbs to the 2 left side intakes, so 1 and 2 were open intakes, the carbs were sticking out of the left side, I need carbs
              1978 XS-Eleven
              • MrWheelie
                • Dec 2007
                • 92
                • Dallas Texas
                #37
                I had the carbs upside down
                1978 XS-Eleven
                • XSokieSPECIAL
                  • Jun 2009
                  • 1631
                  • Tulsa, OK
                  #38
                  WTF?
                  • MrWheelie
                    • Dec 2007
                    • 92
                    • Dallas Texas
                    #39
                    LOL, just kidding, im out of things to do to get it running right
                    1978 XS-Eleven
                    • XSokieSPECIAL
                      • Jun 2009
                      • 1631
                      • Tulsa, OK
                      #40
                      We're going to be there in DFW in about 2 months. Check the south central rallies forum.
                      None of what your saying makes a lick of sense to me.
                      We'll figure it out.
                      • MrWheelie
                        • Dec 2007
                        • 92
                        • Dallas Texas
                        #41
                        PROBLEM SOLVED!
                        carbs have 4 adjustments on a shaft for synchronizing? I turn the 2 that were not fueling, and guess what? they started fueling at idle, idles smooth and revs quick
                        1978 XS-Eleven
                        • MrWheelie
                          • Dec 2007
                          • 92
                          • Dallas Texas
                          #42
                          now im excited again, I got it from the original owner about 4 years ago
                          1978 XS-Eleven
                            #43
                            Nice! Looks like you got one with a rare chrome pachage.
                            • MrWheelie
                              • Dec 2007
                              • 92
                              • Dallas Texas
                              #44
                              chrome package?
                              1978 XS-Eleven
                                #45
                                chrome package?
                                You have a very nice, nearly stone-stock '78. The only non-stock parts I see are the rear shocks, and you're missing the rear turns.
                                I'm probably biased a bit, but I always though these were the best looking of all of them...
                                '78E original owner
