Fill Plug Fix
  • randy
    • Dec 2003
    • 4521
    Fill Plug Fix
    I know a few of you have found alternative filler plugs to fix the dreaded rounded-out allen, but I thought I'd post my solution. I found a Moose Racing # M0102. Originally for Suzi DR250 '90-'92 and DR350 '93-'94. Comes with a 14mm x 1.25 thread so I ran it through my 14mm x 1.5 die and viola! No more allen. Even comes with a new copper crush washer and a magnetic tip. They go for between 12 and 14 bucks each.
    Hi Randy,
    the hard part is getting the old ones out, eh?
    There are other ways but I carefully filed 2 flats on mine and broke them loose with an open-end wrench.
    I fixed mine by brazing a hex. nut on top but that fancy magnet tipped replacement is way hi tech in comparison.
    Theoretically, the thread conversion should not have worked well. How good did it look in practice?
    • randy
      • Dec 2003
      • 4521
      The finished product is in the photo, came out fine
      • D. P. Larmee
        • May 2003
        • 224
        • Evanston, IL
        The oil drain plugs for the XS11 are 14 x 1.5 and can be picked up at Partsnmore for $7.00.
        1980 XS 1100 Standard
        1980 XS 1100 Special
        1982 XJ 1100
        1972 Honda CB 350
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          That being the fill plug, it will not be in the gear oil so the magnet part is moot. Can't hurt though. Way easier to remove as you pointed out. looks good too.
          Pat Kelly
          <p-lkelly@sbcglobal.net>
          1978 XS1100E (The Force)
          1980 XS1100LG (The Dark Side)
          1999 Suburban (The Ship)
          1994 Dodge Spirit (Son #1)
          1968 F100 (Valentine)
            Hi Randy,
            what f**king photo?
            this:- http://home.ptd.net\~theragos\PLUG.JPG
            showed up on my reply but is not on my screen with the original post.
            Must be the electronic equivalent to a plugged pipe somewhere in the system.
            It's that I have had less than stellar results trying to convert one thread to another.
              Well, eff me if it didn't show up on that last reply but the bastard still don't work. WTF?
              • randy
                • Dec 2003
                • 4521
                Funny you should have that problem, Fred. Well, it's not ha-ha funny, but I have the same problem when I use Firefox. As I was posting this very thread, I couldn't see my photo, then when I switched to IE, it came up. I echo your sentiment---WTF??
                Oh, and D P Larmee, yeah, we know they're available, but they all have the dreaded allen!
                • D. P. Larmee
                  • May 2003
                  • 224
                  • Evanston, IL
                  The fill plug is an allen; the drain plug is a hex head with the same threads. It's the same plug that you remove to drain the engine oil, and both middle and final drives.
                  1982 XJ 1100
                  1972 Honda CB 350
                  • D. P. Larmee
                    • May 2003
                    • 224
                    • Evanston, IL
                    I knew I had an extra one around here somewhere. Here she is:
                    1982 XJ 1100
                    1972 Honda CB 350
                    • randy
                      • Dec 2003
                      • 4521
                      OOPS, maybe I should read slower...thought we were all talking about the fill plug...
                      • dpotter58
                        • Aug 2004
                        • 1847
                        • Southern Maryland
                        Hey Randy, why did i think this was a thread bustin my chops??
                        1980 LG
                        1981 LH
                        • cywelchjr
                          XS-XJ Super Guru(Deceased)
                          • 4450
                          • Sacramento, CA
                          I think he is saying that you can use the drain plug as a fill plug because it has the same threads as the fill plug but is a hex head. I'm going to check that out when I get home (gonna grab the drain plug from my old engine and check it for fit.
                            Napa sells one for $4.99 too.
                            • randy
                              • Dec 2003
                              • 4521
                              Dwayne, you feelin' guilty?
                              I don't think the drain plug has enough clearance to use as a fill plug on the final drive? Hey, I've been wrong before...
