Fill Plug Fix
    I don't know where it came from, but the PO put a hex bolt on my final drive, and it works great. Maybe a short, non-magnetic one would be best. Shouldn't be hard to find.
    • randy
      • Dec 2003
      • 4521
      I've looked at the over-the-counter plugs, but all the ones I found had a large flange, too large. If you find out where yours came from, please post it.
        Well, mine is a 13mm hex head (I just took it out to look at it).
        This one is very close, but it's a 17mm hex, and about the same flange as mine. Then, there's this one, with no flange at all, but a 19mm hex head. That ought to work too.
        This one should work too, but it's not as pretty.
        • TomRodgers
          • Jun 2008
          • 492
          • La Porte Indiana
          FWIW......
          i at one time used the red ball off a paddle ball toy to keep oil from spitting out at me.... it was soft enuf to "squeeze" in the filler hole, yet firm enuf to not pop out. TEMPORARY fix.....
          '81H (my first XS ) "Grey Ghost"
          4:1 Jardine w/ headerwrap
          Windjammer(wiring issues)
          New paint/brakes to come!!
          '80G FrankenBike (parts bike)
          '80G to fix "BlackSunshine"
          Stock Pilots/125 mains
          Pod filters; 4:1 Kerker??
          SS Brake lines w/ new M/C's
          LED Brake Lite
          Needs paint....
            Originally posted by TomRodgers
            FWIW......
            MacGyver would be proud!
            • D. P. Larmee
              • May 2003
              • 224
              • Evanston, IL
              Here she is installed in the final drive. The clearance is too tight to get a socket on, but there is plenty of room to get it finger tight and snug with an open end wrench.
              1980 XS 1100 Standard
              1980 XS 1100 Special
              1982 XJ 1100
              1972 Honda CB 350
              • randy
                • Dec 2003
                • 4521
                Nice..that's an XS drain plug?
                • Pat Kelly
                  • 3046
                  • Golden Valley, AZ
                  Note to self...
                  Add paddle ball to tool kit for next trip. Temp filler plug, swat flies, tournikit, pass time in camp.
                  Pat Kelly
                  <p-lkelly@sbcglobal.net>
                  1978 XS1100E (The Force)
                  1980 XS1100LG (The Dark Side)
                  1999 Suburban (The Ship)
                  1994 Dodge Spirit (Son #1)
                  1968 F100 (Valentine)
                  • D. P. Larmee
                    • May 2003
                    • 224
                    • Evanston, IL
                    This one is a replacement from Partsnmore.com (part # 15-0014 on the "engine" tab for the XS11), but it is the same head and thread size as factory. I put a factory one in another bike after I stripped the original plug. It worked great so I ordered a bunch of them from partsnmore for my other bikes.
                    1982 XJ 1100
                    1972 Honda CB 350
                      Hey, what ever you use, if you acccompany the bolt with a nylon washer, it will make removal a breeze!
                        Also, the crush washer off an old sparkplug is just the right size, and maybe a bit easier to find than a nylon washer. Just don't do the gorilla thing when you torque it in.
