Carb brushes ???
  • Carb brushes ???
    anyone have a link for little twisted brushes that will clean them wee tiny holes?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    A good carb cleaner will clean those passages.You shouldn't need brushes.
    If you really need them though, pipe cleaning brushes.Should be able to get them at a tobacco shop.
    80 SG XS1100
    14 Victory Cross Country
      I can't imagine any pipe cleaners being small enough to get into those tiny holes. Usually, carb cleaner and compressed air is all that is needed. Possibly, a single strand of wire might help too.
        Harbor Freight Tools has a set of airgun brushes that are pretty small. About $4.99 if I remember correctly.
        Thought I should use a universally recognized item for a size reference.
        Everything on hold...
          Those are the ones you need and some kits for spray guns have brushes that are even smaller along with a verity of push pins. Spray carb cleaner does not dissolve hardened fuel gum on contact. Soaking and brushing is the way to go.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
            I have not used these brushes with carb cleaner. The thought just came to me that Gumout or something like it may just melt the bristles. Would be a safer bet to test that first before running the brush down inside the carb with a big squirt of cleaner.
              So far I have not had any issues with tooth brushes or these small bottle brushes melting but I don't leave them soaking or use them while the carb part being cleaned is submersed in the cleaner.
              Rob
              1978 XS500E
              1981 Suzuki GS1100
