anyone have a link for little twisted brushes that will clean them wee tiny holes?
Carb brushes ???
Carb brushes ???
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
I can't imagine any pipe cleaners being small enough to get into those tiny holes. Usually, carb cleaner and compressed air is all that is needed. Possibly, a single strand of wire might help too.1980 XS850SG - Sold
-H. FordComment
Harbor Freight Tools has a set of airgun brushes that are pretty small. About $4.99 if I remember correctly.
Thought I should use a universally recognized item for a size reference.
Everything on hold...Comment
Those are the ones you need and some kits for spray guns have brushes that are even smaller along with a verity of push pins. Spray carb cleaner does not dissolve hardened fuel gum on contact. Soaking and brushing is the way to go.
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 CustomComment
I have not used these brushes with carb cleaner. The thought just came to me that Gumout or something like it may just melt the bristles. Would be a safer bet to test that first before running the brush down inside the carb with a big squirt of cleaner.RIP Whiskers (Shop Boss) 25+yrs
So far I have not had any issues with tooth brushes or these small bottle brushes melting but I don't leave them soaking or use them while the carb part being cleaned is submersed in the cleaner.
1978 XS500E
1981 Suzuki GS1100
