Spline lube
  • dbeardslee
    • Nov 2007
    • 4385
    • Maineville, OH
    Spline lube
    As most of you know, proper lubrication of the driveshaft splines requires disassembly and direct application of a high molybdenum disulfide grease directly to the splines every 10k miles. In my research I found that Honda adamantly recommends a minimum moly content of 60% for lubricating Goldwing splines. Even though these aren't Hondas, I used that as my target content, figuring that the more moly the better. I found the bel-ray stuff difficult to locate, but what I did find was Loctite Moly Paste. It's 65% molybdenum disulfide, and is available in an 8 oz. jar that includes an applicator brush attached to the lid. I thought that was a nice touch, as moly is some sticky stuff and adheres to flesh about as well as it adheres to metal. It's pretty expensive - about $20 plus shipping for 8 oz.'s - but that is essentially a lifetime supply for an XS. Anyway, I just thought I would pass it along.
    • 6765
    Excellent info...and Thanks! I have used a moly60 spline lube on my Honda ST1100...it is recommended at every rear tire change...last fall I discovered that my rear splines on the XJ1100 were dry...dunno the last time they got lubed...but upon further inspection the splines were in good condition and got lubed up...the rear tire is due to be changed this Spring so I'll lube everything again...Where did you find the Loctite Moly paste?
    2005 Honda SilverWing 600
    2018 Honda PC-Xpress 150
      +1 using the Honda Moly60 lube on the splines..
      • dbeardslee
        • Nov 2007
        • 4385
        • Maineville, OH
        I ordered it from waresdirect - $19.66 plus $9.99 shipping.
        • motorhead
          • Nov 2009
          • 94
          • Buford,ga
          We use a moly paste to grease the splines on outdrives on boats .There is very commonly 400+ horsepower put through this spline coupling.I'm going to check first of the week and get moly content .It is some good stuff ,and is what I'll be putting in the splines on my 1100.Just saying
          • latexeses
            • Jun 2008
            • 1491
            • California
            I was cruising a scrap yard a couple years back and found 3 1lb cans of military molybdenum disulfide grease. Got them all for a buck. The grease has dried a bit but that shouldn't affect the moly. I found out that you should be very careful using it. If not it will be in your ears, on your forehead and nose in no time flat. Personal experience.
            Anyone have any idea what the % moly might be in there?
            G-353
            GMD
            GREASE
            MIL-G-21164B (ASG) AM 1
            9150-754-2595
            ELECTROFILM INC. 2530
            MAY 66 BATCH
            DSA 600-12024
            AML 78267-64
            Any place I could find out?
            Everything on hold...
              G-353
              GMD
              GREASE
              9150-754-2595
              MAY 66 BATCH
              DSA 600-12024
              AML 78267-64
              Hi Latexesse That Mil G number is the Mil Specification it would have to meet. If you can find that you will know.
              • latexeses
                • Jun 2008
                • 1491
                • California
                MaximPhil,
                I have found mention of that number but without the "B" suffiix. Think it is a "G" now. Nothing I have found yet gives me a hint. I suspect that the % would be up there. I imagine it would have been used on anything from small arms to field artillery.
                Anyone out there working for GSA?
                • dbeardslee
                  • Nov 2007
                  • 4385
                  • Maineville, OH
                  I couldn't find the 'b' suffix either, but I did find the 'd'. The 'd' suffix showed a Nato equivalent number of G-353, which got me to Shell Grease 33 MS, which meets that spec. That appears to have a moly content between 3 and 8.99%. Here's a link to the page with the info. If you click on the msds sheet it will give you the info for the Shell 33. It shows it as meeting MIL-G-21164 on the first page, but when you look at the msds it shows a different mil spec number. I found another page with the info on MIL-G-21164D - spec sheet - click on the funny looking green arrow and it will open a pdf. Unfortunately the spec sheet defines performance - not content. Also, according to the info I could glean, the last character in the mil spec number is a revision code, so unless we knew what the revision was for, the information is all somewhat suspect. Best I could do. If it did turn out to be high moly content that would be a real steal - 3 pounds would be like $300-400 worth of moly paste. Then again, if it's just moly fortified grease as the tech sheets suggest, you're probably better off not using it in critical locations as it sounds like it's dried out. 3% moly grease doesn't cost much more than regular grease.
                  • latexeses
                    • Jun 2008
                    • 1491
                    • California
                    Yea, it probably wouldn't be the best grease for the splines. According to MSDS it wouldn't be too good for injecting under the skin at high preasure.
                    I have used it on some "rubbing metal surfaces" as the application suggests and it hangs on like a leach.
                    I think the letter suffix must just be something like a "batch" designation or something like that. I could only hope it is a "concentration" designation.
                    MaximPhil, dbeardslee,
                    Thanks for the help. I might find an old tank mechanic or someone who still has that stuff under his (or her) fingernails.
                    Maybe I could get my hands on a gallon of the grease used to grease the tracks on the crawler they use to move the Space Shuttle! Or I might already have 3 cans Thanks again.
                    • Rickrod3
                      • Jun 2009
                      • 721
                      • Oakland, New Jersey
                      Would this stuff work?
                      Sta-Lube Moly-Graph Extreme Pressure Multi-Purpose Lithium Grease is the best general purpose grease for a wide range of applications. Timken load of 45 lbs.
                      Tia
                      Rick
                      650SF
                      XS1100SG Project bike
                        Runnin' and Gunnin'
                        Tia
                        Rick
                        That item looks like it would fit inside a grease gun. It's similar to the stuff I used. (Gawd! Somebody tell me if I'm DOOMED!!)
                        You're not thinking that you can just grease the Zirk fitting and be good to go, are you??
                        The design of the rear shaft/splines and the placement of that zirk fitting results in a situation where you can gun it with grease all ya want but still leave the right areas unlubricated.
                        Disassembly and lube is strongly advised.
                        • Rickrod3
                          • Jun 2009
                          • 721
                          Naw I read that they have to be taken apart.
                          I'm pulling brakes, wheel to lube the bearings going to pull the final drive to lube them as well. I asked a couple of local suppliers for the loctite moly paste but, they cannot get it. One of them offered me the CRC one its also alot cheaper.
                          Rick
                          650SF
                            I've got a ton of miles on them so far with plain old wheel bearing grease...
                            It's kinda like the motor oil threads of which oil is best. Just change the stuff occasionally (or in this case, re-apply) and you'll be fine..... whatever brand.
                            Just my 2 cents.
                            • dbeardslee
                              • Nov 2007
                              • 4385
                              • Maineville, OH
                              The thing about molybdenum is that it bonds with metal, so even after the grease component has dried out it still provides lubrication. Maybe it's overkill, but I like the high moly content for the splines 'cause they don't see daylight very often. I figure a good quality lube is relatively cheap compared to breakdowns.
