project custom build - 79 XS1100
  • paulbaut
    • Dec 2009
    • 32
    • philippines
    Originally posted by Mashermoto
    PaulBaut,
    Show some more detail about that exhaust system What are the mufflers from and how did you manufacture the pipes
    hi there, we customized the exhaust...(check the picture with side elevation view)its like 4 to 2 then connected them to a baffle or collector right under the swingarm pivot, then projected upward a single pipe inside the swing arm together with the rear tires then had a dual muffler end...a bit tricky in achieving the look, we had to make sure the swingarm and even the tires wont touch the muffler pipes
    Paul B. Bautista
    Manila, Philippines
    XS1100 Midnight Special Cafe Racer
    TZR250 Street Tracker
    1986 Honda GB400 TT
    • paulbaut
      • Dec 2009
      • 32
      • philippines
      End Result of the Build
      [IMG][/IMG]
      Paul B. Bautista
      Manila, Philippines
      1986 Honda GB400 TT
      • RODS454
        • Dec 2009
        • 83
        • Midlothian, Tx
        End Results
        Very Cool. I like the way it all turned out. Especially the routing of the exhaust. I'd like to hear it , if you can figure out how to post a video with sound. Good job.
        RODS454
        "I'd rather be fishin'"
        1980sg "Cruise Missle"
        2002A Goldwing
        • Mathh
          • Nov 2006
          • 672
          • Beek, Netherlands
          One sweet looking bike
          MV Agusta Brutale 910R '06.
          Yamaha MT-09 Tracer '15 grey.
          • Yahman
            • Mar 2008
            • 779
            • Salem, OR
            Congrats... Very nice, well worth the effort.
            Larry
            82 XJ1100
            80 XS1100G (Project bike)
            64 Yamaha YA-6
            77 Suzuki TS-185
            • petejw
              • 2269
              • sydney australia
              +1 That turned out very nice,
              congrats, i hope it rides as good as it looks.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • psycoreefer
                • Feb 2008
                • 1557
                • Minden, NV
                Originally posted by paulbaut
                i will try to post the pix of the converted wheel and explain how we melted a chunk of high grade aluminum then filled up the space of the sprocket type hub of the fzx750 rear wheel....tnx for the compliments,robbo.
                Do you have any more info on how you made up that rear rim and what mods were done to make that swing arm fit?
                1979 xs1100 Special -
                My Bike:
                [link is broken]
                • cueball
                  • Jun 2003
                  • 375
                  • Nth Albury NSW Australia 2640
                  Damn good effort
                  Thanks for the pics and the ideas
                  • Coopz
                    • Feb 2010
                    • 40
                    • Adelaide, South Australia
                    That thing is hot, well done
                      • 8736
                      Nice build! What bike are the forks from?
                        • 8736
                        GSXR forks, went back and read the first post. Let us know how she handles.
                        • paulbaut
                          • Dec 2009
                          • 32
                          • philippines
                          tnx guys! Rides well and smooth...with its low stance and adequately wider 150 rear tire,it rides smoothly and hugs the road especially at high speed...with the sound,it has that grunt at 4k rpm up...il try to post a video of it running and cruising..hv 2 find a video cam 1st.haha...its really worth it...the swingarm by the way is from a SECA...u can use a vmax rim at the back, as 4 this build,we used the baby vmax rim that is lying around the shop, we modified it from a sprocket type to fit shaft drive by melting high grade aluminum inside the hollow inner part of the hub...to save u the trouble just use a vmax rim instead..cheers guys!
                          Paul B. Bautista
                          Manila, Philippines
                          1986 Honda GB400 TT
                          • res1uqtp
                            • May 2009
                            • 84
                            • East Central IL
                            Amazing ... simply amazing!!!!!
                            Looks fantastic man ... thanks for sharing your work. You should be VERY proud of that ride
                            My Stable:
                            2006 Triumph Bonneville Black
                            1979 Yamaha XS11 Special (2 of them)
                            1982 Yamaha XS400 Heritage Special
                            1981 Suzuki GS550 E
                            1976 Honda CB550F Supersport
                            • paulbaut
                              • Dec 2009
                              • 32
                              • philippines
                              hi guys,i made measurements on the SECA swingarm vs. the Virago...virago is 1 1/2'' longer...so a virago swingarm can also be an alternative if u want 2 put ur mufflers under the seat as well.
                              Paul B. Bautista
                              Manila, Philippines
                              1986 Honda GB400 TT
                              • robbo
                                • 106
                                • Aldershot. UK
                                fantastic
                                well done a fantastic looking bike...just goes to show the old xs can still look contemporary with a little pimp up hope you have plenty of time to enjoy her now.
                                Rob
                                XS Eleven SF
                                Could this be the finest Triumph Bonneville ever built ?
                                (Cycle January 1979)
