Picked up another XS11...
  • rpgoerlich
    • Dec 2007
    • 643
    • Katy, Tx
    Thanks, Was hoping to ride it up to MOM this year.
    BTW How are you doing? That seat work out ok ?
    Richard
      • 2083
      Hi Richard, Great looking steed You've put together there. One question. I'm curios as to how hot do the bottom of your hardbags get as I will be installing the same setup on my '80G? My pipes are just about the same length as Yours and I was thinking about an aluminum insulator plate affixed to the underside of the hardbags if necessary.
      • rpgoerlich
        • Dec 2007
        • 643
        • Katy, Tx
        Something I didn't check when I got it to work that day.The pipes on this 81 Venturer end just in front of the rear axle. On my 80G they go just to the rear of the final drive. I suppose if you sat there idling for a while they might heat up, while moving shouldn't be a problem. My bags have another hard plastic frame it mounts to underneath it. Adds a bit of insulation there which should help to keep the beer cold .
        Richard
          • 6762
          #34
          Richard ...what a great bike you have found! Venturers are rare and in my mind the most desireable of the XS11s'. I have been looking for one for over a year. Graet find and a great job bringing back to life!
            #35
            Hey Richard, I'm healing up pretty good. Everyday things I thouhgt I could not do two weeks ago I do effortlessly. So I am learning to adapt to life with one arm and one leg for a while. In a month or so I should get the other ones back.
            That seat worked out great!! It fits perfectly and looks awesome on the bike. As soon as I can get the bolt I snapped off repaired it will be ready to find a new owner. I think at this point I will just drop a couple hundred off the price and let the next owner paint the tank.
            Then it is on to dismantling Thunderstruck to determine the extent of the damage.
            Just how these things go, always something to fix, good thing I like fixing them. Kinda like the exploding head on your Venturer.
            • WMarshy
              • Apr 2009
              • 2402
              • Mexico NY
              #36
              I have a similar set on my 'F' and never had a heat problem with the bags, seemed like they got more heat from being in direct sun all day than the exhaust.
              Sorry to hear about your engine problem Rich, hope the next engine is problem free!
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
              '84 Chevy K-10 "Big Blue"
                • 2083
                "Something I didn't check when I got it to work that day.The pipes on this 81 Venturer end just in front of the rear axle. On my 80G they go just to the rear of the final drive. I suppose if you sat there idling for a while they might heat up, while moving shouldn't be a problem. My bags have another hard plastic frame it mounts to underneath it. Adds a bit of insulation there which should help to keep the beer cold ."
                Thanks, looks like You got all Your ducks in a row
                "I have a similar set on my 'F' and never had a heat problem with the bags, seemed like they got more heat from being in direct sun all day than the exhaust."
                That's good info and time saved on fabbing heat shields will be used to ...well...fabbing something else for another project/obsession
                • WMarshy
                  • Apr 2009
                  • 2402
                  • Mexico NY
                  #38
                  Originally posted by rpgoerlich
                  ...My bags have another hard plastic frame it mounts to underneath it. Adds a bit of insulation there which should help to keep the beer cold .
                  Just put the bag of charcoal in that side if you have a 4-1. A 12 lb bad fits perfect
                  '79 XS11 F
                  Stock except K&N
                  '79 XS11 SF
                  Stock, no title.
                  • rpgoerlich
                    • Dec 2007
                    • 643
                    • Katy, Tx
                    #39
                    Finally finished reconditioning the replacement head for it last weekend. Took the time last night to pull the damaged head off of it. What I found kind of disturbed me. #4 exhaust shim bucket is stuck so until I cut it out I wont know exactly what failed. But When I removed #2 exhaust shim bucket both valve springs were broken and the valve wont come through the valve guide. Piston #2 & #4 will get a closer inspection tonight.
                    Had a bit of a mishap on the way home from work. 55miles on it and a mile from home.
                    It appears #4 exhaust shim bucket overheated and hung, allowing the shim enough clearance to pop out after hearing the valve hit and be driven through the front of the head...
                    I have another head that should be here this week.
                    Probably be riding the special up to MOM.
                    Richard
