so i need new coils and plugs for my 1100 special. what do people think about the difference between the reg. and the green (high output) from mikesxs? is there really that big of a difference?
coils and plugs
'80 XS1100 SG
https://www.youtube.com/watch?v=x_Z4cjUlIo4 -
Search for mikes XS coils.
There is a recent thread on the conversion.
Maybe add green in the search.John
Now: '78 XS1100E 750 FD Mod (Big Dog)
'81 CB900C ( 10 Speed)
'78 CB750F ( The F)
'76 CB400F ( The Elf)
New '82 Honda MB5 Ring Ding
Then: '76 CB550K
'78 CB750F
'84 VF1100S
And still Looking!Comment
so here is the list i came up with....i am hoping to buy and ship everything only once....best laid plans, right? but that is the hope.
am i missing anything?
Part #17-6810 (I need two of these) coils
Part #23-2906 (I need two sets of these) spark plug wires
Part #17-6830 (I need two sets of these) coil tower boots
Part #17-6831 (I think i need these, and two sets if I do) high tension wire ends
Part #23-3113 (do I need 4 of these? I have 4 on my bike, but I have two different styles now, I don't know why) resister spark plug cap.
does that sound like it? have a great thanksgiving to everyone!!!
thanks so much!!!1980 XS 1100 Special (working to be my daily ride)Comment
โฎComment
A few folks like myself have put the MIkesXS 90 degree caps on their 2-3 plugs without any problems. Depending on how long you run your plug wires, they may LAY on the head when using the 90 degree boots. However, you could also harvest the extra protective sleeve off of the old wires to put over the new ones so that they wouldn't get rubbed IF they end up laying on the head!
T.C.T. C. Gresham
I'm running the 90 deg ngk caps on all 4 like TC said.No problems,and yes I can tell the difference between the green xs and the stock coils.I also use the irodiam plugs.(sp?)If you go with the high output coils don't forget to remove the resister.
Terry1980 special (Phyllis)
1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner modComment
thank you so much!!! the amount of time (and money) you guys are going to save ime in getting the things i need to do it right the first time is going to be insane!!!!!(now i just have to do it right the first time....yeah, right!)
thanks again for all the help!!!1980 XS 1100 Special (working to be my daily ride)Comment
Where to find plug caps?
Bike bandit seems to have both kinds. But their $6 shipping is a little too much for $14.00 items. Amazon/ebay are worse. Autozone and Kraagen had no clue when I told them the NGK part numbers.
Do you know who have them at a physical location?dontlikeoc
1981 XS1100 Special Edition
Alhambra, CAComment
Go to a NAPA parts store. They should be able to get them for you! Make sure you DO NOT get the "stock" style caps. You want the cap that keeps the end on the spark plug, so you can use ANY type of plug.Ray Matteis
I went to Napa parts to try and get some and they looked at me like I was crazy. That is especially strange as my Yamaha dealer said that is where they get them because the yamaha parts are too expensive.Cy
