coils and plugs
  • 1st bike
    • Nov 2009
    • 258
    • indiana
    coils and plugs
    so i need new coils and plugs for my 1100 special. what do people think about the difference between the reg. and the green (high output) from mikesxs? is there really that big of a difference?
    1980 XS 1100 Special (working to be my daily ride)
  • STEPPENWOLF
    • Jan 2007
    • 4188
    • CINCINNATI OH
    Yes....
    '80 XS1100 SG
    • 1st bike
      • Nov 2009
      • 258
      • indiana
      are they a big pain to instal or pretty easy if i just take it slow and think it through?
      • jjwaller
        • Oct 2005
        • 242
        • Gautier, MS
        Search for mikes XS coils.
        There is a recent thread on the conversion.
        Maybe add green in the search.
        John
        Now: '78 XS1100E 750 FD Mod (Big Dog)
        '81 CB900C ( 10 Speed)
        '78 CB750F ( The F)
        '76 CB400F ( The Elf)
        New '82 Honda MB5 Ring Ding
        Then: '76 CB550K
        '78 CB750F
        '84 VF1100S
        And still Looking!
        • 1st bike
          • Nov 2009
          • 258
          • indiana
          jj..Thanks man! i did just that, and i am on my way through the thread now. very helpful!! this site is amazing, thank you all and have a great thanksgiving to everyone!
          • 1st bike
            • Nov 2009
            • 258
            • indiana
            so here is the list i came up with....i am hoping to buy and ship everything only once....best laid plans, right? but that is the hope.
            am i missing anything?
            Part #17-6810 (I need two of these) coils
            Part #23-2906 (I need two sets of these) spark plug wires
            Part #17-6830 (I need two sets of these) coil tower boots
            Part #17-6831 (I think i need these, and two sets if I do) high tension wire ends
            Part #23-3113 (do I need 4 of these? I have 4 on my bike, but I have two different styles now, I don't know why) resister spark plug cap.
            does that sound like it? have a great thanksgiving to everyone!!!
            thanks so much!!!
              • 8796
              MikesXS doesn't sell the correct plug caps for the #2 + #3 cyls. of the 1100, as they are longer and angled differently. The Mikes P/N 23-3113 is correct for cyls. 1+4. The NGK P/N for cyls. 2+3 is XB05F. Cyl 2+3 NGK P/N is LB05F.
              http://www.parkeryamaha.com/ngksparkplugcapxb05f.aspx
                A few folks like myself have put the MIkesXS 90 degree caps on their 2-3 plugs without any problems. Depending on how long you run your plug wires, they may LAY on the head when using the 90 degree boots. However, you could also harvest the extra protective sleeve off of the old wires to put over the new ones so that they wouldn't get rubbed IF they end up laying on the head!
                  • 8796
                  correction
                  Cyl 2+3 NGK P/N LB05
                  The above should be LB05 for 1+4,
                  • tw1980
                    • Apr 2009
                    • 662
                    • Bend OR
                    I'm running the 90 deg ngk caps on all 4 like TC said.No problems,and yes I can tell the difference between the green xs and the stock coils.I also use the irodiam plugs.(sp?)If you go with the high output coils don't forget to remove the resister.
                    Terry
                    1980 special (Phyllis)
                    1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
                    • Lunatic
                      • May 2006
                      • 200
                      • Watertown SD
                      Excellent
                      Great information. Thanks guys
                      • 1st bike
                        • Nov 2009
                        • 258
                        • indiana
                        thank you so much!!! the amount of time (and money) you guys are going to save ime in getting the things i need to do it right the first time is going to be insane!!!!!(now i just have to do it right the first time....yeah, right!)
                        thanks again for all the help!!!
                        • dontlikeoc
                          • Nov 2009
                          • 173
                          • Alhambra, CA
                          Where to find plug caps?
                          Bike bandit seems to have both kinds. But their $6 shipping is a little too much for $14.00 items. Amazon/ebay are worse. Autozone and Kraagen had no clue when I told them the NGK part numbers.
                          Do you know who have them at a physical location?
                          dontlikeoc
                          1981 XS1100 Special Edition
                          Alhambra, CA
                            • 7765
                            Go to a NAPA parts store. They should be able to get them for you! Make sure you DO NOT get the "stock" style caps. You want the cap that keeps the end on the spark plug, so you can use ANY type of plug.
                              I went to Napa parts to try and get some and they looked at me like I was crazy. That is especially strange as my Yamaha dealer said that is where they get them because the yamaha parts are too expensive.
