Uni-joint replace number
  • Rasputin
    • 3193
    • Lacombe, Alberta, Canada
    I took the u-joint down there and I took the yoke. We measured it up and compared it to the one they have in stock. I dont recollect the exact difference but it was not enough that I would be afraid to use it. .00 something kinda difference. They also told me it crossed to a 392 which is made by progressive I think. Could be another manufacturer that starts with a letter P and I just have progressive on my mind though, but the number is the same.
    2-79 XS1100 SF
    2-78 XS1100 E Best bike Ever
    • Steptoe
      • 175
      • Thabeban,Bundaberg QLD , Australia
      lets see
      Mr big,, $168 is for the yoke & joint as you know which is why I started hunting else where,, shipping across the "pond" wouldn't be that much.
      B WALKER 5,, I don,t get it, external measurements are from outside to outside, so measuring from anywhere else won,t be fine.
      [ there is a poofteenth of clearance because the clips are a slide fit not a press fit]
      the joint I got slipped straight in, no shims, centred exactly,,,,, I have tagged this as uni/cross joint,,if needed I can get them & ship to where needed when needed, I'll buy a couple & keep them here for later.
      never ride faster than your gaurdian angel
      can fly
      1981 rh 5N5
      MIDNIGHTSPECIAL
      1188cc
      4 into 1 pipes with a transac muffler,
      as the motorcycling gods intended everything else stock std
      http://s856.photobucket.com/home/steptoexs11
      http://steptoexs11.webs.com/
      http://www.youtube.com/my_videos?feature=mhum
      1982 vf750 sabre
      • b.walker5
        • Feb 2009
        • 1745
        • Invercargill, New Zealand
        Simple enough, some manufacturers measure from inside to inside and dont include groove width. So if the groove / clip width is 2.5mm and the internal measurement is 35mm then the total is 40. Bought one today for 32 bucks, even though I dont need it (never hurts to have spares on hand). Measures perfectly to 40mm, including groove width. Matsuba UJ-112. Direct Cross from Koyo UJ N2057, which is the original part. Half the price of the 901004 in this part of the world. To you guys in the states, Neapco 1-0028 is what you want.
        Might be time we started compiling a list of aftermarket parts, numbers and suppliers for our bikes that can be posted as a tech tip.
        • Steptoe
          • 175
          not a bad idea
          might take some working out though, as we have just found out .
          a part number "down under" obviously doesn't work up "on top"
          but it certainly might be worth a look by admin guys
          can fly
          1981 rh 5N5
          MIDNIGHTSPECIAL
          1188cc
          1982 vf750 sabre
          • DAVINCI
            • Jan 2011
            • 1048
            • Cedar Mountain, NC
            Supplier here...
            The U-Joint Store.
            • James England
              • 3039
              • North of England
              Originally posted by DAVINCI
              Nice one. Exactly what was needed
