Pacifico Fairing
  • saddo
    • 21
    • Forest of Dean, England.
    XSrunner,
    Groovy paint job, did you do that?
    Interested to know how the head temp is done. Is this an oil temp gauge with the sensor bolted to the head?
    1978 "E" & 1979 "SF" trike (being built)
    • GARTHXS
      • Nov 2007
      • 1631
      • Seattle
      wires
      Radio Shack will have what you need there. Look for the Molex connectors in drawers. Don't expect the store people to know what you're talking about though. Be sure to get the right gauge wire too.
      yeah I saw the connecters online at the shack , but they have a very limited supply of wire there , I guess I'll try Kragen for the wire, also I guess I will bite the bullet and buy a new windshield .
      91 kwaka kz1000p
      Stock
      ( Insert clever quote here )
      • XSrunner
        • Feb 2008
        • 97
        • Batemans Bay AUSTRALIA
        HI SADDO the head temp wire goes under no1 spark plug and the oil temp sender replaces the sump plug on the bottom of motor .don't know if its right but the head temp sits between 300and 350 deg F .oil temp sits around 180 to 200 deg F the PO done the paint job 13yrs ago. he brought the bike over with him to AUSTRALIA in 1980. i have had it 18 months he was 73yrs old and couldn't handle the size of it anymore the fully touring version was not available in australia.I would suggest getting a set of PROGRESSIVE FORK SPRINGS for it it make a big difference to the front end (not as soft and bouncey) i dont think yamaha allowed for the extra weight the faring has..
        JOHN'O
        Xs1100E 1978
        American Import Cruiser
        • GARTHXS
          • Nov 2007
          • 1631
          • Seattle
          #34
          pigtail
          So I wired up my pigtail today, but as I was inspecting my work I noticed I have an extra wire D'oh! I guess I can always add somthing later
          91 kwaka kz1000p
          Stock
          • GARTHXS
            • Nov 2007
            • 1631
            • Seattle
            #35
            fairing wiring?
            so I am replacing the plug on the fairing side , and the wire color is very confusing , does anybody know what the correct connections are ?
            91 kwaka kz1000p
            Stock
              • 7832
              Give me 24 hours, and I'll try to get an answer for you. I need to get to storage to check my fairing.
              The oil is correct, but the temp is wrong. It should be under the number two plug. The center two DO get more heat than the outside jugs...
              • GARTHXS
                • Nov 2007
                • 1631
                • Seattle
                #37
                update,
                So I think I have it pretty much figured out except for the signals on the fairing anybody know how it hooks up
                91 kwaka kz1000p
                Stock
                  • 7832
                  the fairing has running lights AND signals in the one light. IIRC, the blue is for the running lights, and dark green right, brown left, same as the bike. The easy way is turn on one turn signal, to a "temp" connection to one of two wires and see what side is on. It does not have to be blinking, so you can test with the engine off.
                  • GARTHXS
                    • Nov 2007
                    • 1631
                    • Seattle
                    #39
                    lets pretend!
                    Ok don't pretend , I am practicaly retarded when it comes to wiring so if tell me exactly how to hook up the wires from my bike to the fairing , color to color then it would be much easier for me !
                    91 kwaka kz1000p
                    Stock
                    • saddo
                      • 21
                      #40
                      Wiring Instructions
                      Garth,
                      Go to Catonic Bug's site (link a few messages below). There you'll find a PDF of the Pacifico fitting instructions that contains a schematic of how it should be wired.
                      I've not looked at it myself as I've UK specced my lighting. The separate running lights have been temporarily disconnected to be replaced by a repeater turn signal to try and help the car drivers notice when I'm moving over.
                      Hope the fitting instructions help.
                      • GARTHXS
                        • Nov 2007
                        • 1631
                        • Seattle
                        #41
                        Heres whats going on
                        Fairing
                        black= ground for head light=black
                        white=headlightdark =green
                        yellow=headlight=yellow
                        brown=left signal=brown
                        2x greens=???
                        red=instuments=red
                        2xred/white=cig lighter/istruments
                        light blue= instruments light =large brown
                        b/w=oil temp
                        2 orange= extra
                        extra white wire?
                        where do I hook up the lapiz and green wires for signals
                        91 kwaka kz1000p
                        Stock
                        • GARTHXS
                          • Nov 2007
                          • 1631
                          • Seattle
                          #42
                          i did
                          The diagram is not that great, unfortunately it was made 31 years ago and not as well as are bikes! and not in color(D'oh)
                          91 kwaka kz1000p
                          Stock
                          • Crazcnuk
                            • Aug 2006
                            • 2980
                            • Hinton, AB, Canada
                            #43
                            "Looked at your fairing, very nice. Wish I had the square headlight version but mine's off an SF, winds me up that the front indicators are round and the rear square. Just me I suppose."
                            If yours is a Pacifico, they make a rectangular headlight conversion kit:
                            http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
                            '05 ST1300
                            • saddo
                              • 21
                              #44
                              Rlound to Square
                              Excellent find. I wonder if they do the same with the signal lenses?
                              • GARTHXS
                                • Nov 2007
                                • 1631
                                • Seattle
                                #45
                                hmmm?
                                maybe its because my 78 has a 80g wiring harness, I guess I will try to figure it out agan tomorrow
                                91 kwaka kz1000p
                                Stock
