Pacifico Fairing
  • saddo
    • 21
    • Forest of Dean, England.
    Pacifico Fairing
    I'm thinking of fitting a Yamaha/Pacifico fairing to a UK spec '78 E.
    Anybody got any tips on fitting it and riding. I've never ridden a bike where I can't see the front wheel.
    Cheers.
    1978 "E" & 1979 "SF" trike (being built)
  • CatatonicBug
    • 6117
    • Clinton, UT
    Welcome to the forum!
    Do you have the factory mounting bracket? Once you have that, just bolt it on and ride! Of course, you'll need to do some wiring changes for the headlight/signals, but that's all part of the pigtail.
    Don't worry about not seeing the wheel - once something is that close, it's not worth worrying about anyway. I LOVE riding with a fairing, and from what I've heard, the Pacifico one is the best (though I prefer the look of the Vetter). Since the Pacifico was originally designed specifically for the '78, it should fit right on with no problems.
    • mro
      • Oct 2005
      • 4276
      • Hayward, California
      Not a Pacifico ...
      SF regular ride
      most of the time is spent at highway speeds and is much easier on the body sitting behind a fairing.
      As for mounting. Mine had rubber waashers about 26mm across. (total 4 bolts/4 rubber washers/8 metal washers) I replaced them with a strip of 3mm thick rubber same width as the frame and the full length of the mounting area.
      If I put my other Vetter on one of the XSes will do same.
      mro
      • mro
        • Oct 2005
        • 4276
        Btw
        Never notice not seeing all of the front wheel
        mro
        • devilschld
          • Aug 2008
          • 174
          • kansas
          i just got my new fairing and am working on getting it painted to match the rest of the bike.
          1980 xs1100 sg.
            • 7766
            I have a Vetter on the bike now, and can't wait to get my Pacifico back! The Vetter works, but the Pacifico works MUCH better, IMHO. Yamaha had TWO brackets to hold the fairing on, and they worked very well. The fairing puts the headlight out about 10", but has a better shape for the wind. In '78, when I had my full dress, I could STILL cruise at 125 MPH ALL day long with throttle left over.
            I DO have some photo's of the mounts if you need it.
            • GARTHXS
              • Nov 2007
              • 1631
              • Seattle
              here is good a place as any
              Saddo I am planning to mount one of these pacifico as well , we should work together and post, albeit from the otherside of the world. If you go to catatonic bugs website he has the manual in pdf format , but no pics
              91 kwaka kz1000p
              Stock
              ( Insert clever quote here )
              • saddo
                • 21
                The English winter is on its way so I could really use the extra protection a fairing gives right now.
                I've got both brackets, rubbers and lowers to fit. Just a matter of getting round to it now.
                Thanks for all your help. I'll post some pictures when it's on.
                • wa407mpp
                  • Jul 2007
                  • 717
                  Do you have the big 6 gallon gas tank? If so you might have a problem fitting the fairing around it. If you want to trade to the smaller 5 gallon tank, let me know.
                  Fastmover
                  lion". SHL
                  78 XS1100e
                  • Pat Kelly
                    • 3046
                    • Golden Valley, AZ
                    I have that Pacifico fairing with lowers and the 6.5 gal tank. It fits fine.
                    Pat Kelly
                    <p-lkelly@sbcglobal.net>
                    1978 XS1100E (The Force)
                    1980 XS1100LG (The Dark Side)
                    1999 Suburban (The Ship)
                    1994 Dodge Spirit (Son #1)
                    1968 F100 (Valentine)
                    • wa407mpp
                      • Jul 2007
                      • 717
                      Hey! ya can't blame a guy for trying
                      Fastmover
                      lion". SHL
                      78 XS1100e
                      • saddo
                        • 21
                        Big Tank
                        Yep, I've got the big tank. I've had a trial fit and the electrical connector is too-near the tank to plug the loom on to it. I've unclipped the connector and pushed it into the fairing and connected the loom to it in there. I'll get a grommet to stop any water ingress (big problem in the UK).
                        • GARTHXS
                          • Nov 2007
                          • 1631
                          • Seattle
                          pics?
                          Can you show us how the bracket fits on?
                          91 kwaka kz1000p
                          Stock
                          • GARTHXS
                            • Nov 2007
                            • 1631
                            • Seattle
                            bolts?
                            So I picked my fairing today and the brackets , what size bolts do I need to mount it ?
                            91 kwaka kz1000p
                            Stock
                            • wa407mpp
                              • Jul 2007
                              • 717
                              I'd just relocate the plug to a better location and cover the old hole, it works better that way, you can disconnect it whenever you need to do any electrical work. In fact I mounted two plugs, because with all the crap I have on my bike, one nine pin plug isn't enough.
                              Fastmover
                              lion". SHL
                              78 XS1100e
