Does anyone know how the wiring should be inside the on off switch housing? there are 2 red wires and a blue wire for the starter button.
on off switch
Have you checked out the wiring diagram in the manual? That might help you. It's been a while since I opened mine up, so I don't remember what is in there.1980 XS850SG - Sold
-H. Ford -
Are you talking about the handle bar mounted emergency shutoff switch? That housing has that switch and the starter button.
The emergency shutoff switch completed the circuit between the two red wires. The starter button completed the gtounding loop for the starter solenoid, so the blue wire and a black wire run to the starter button.Life is what happens while your planning everything else!
78 XS750Comment
the wires to the starter button are fine. it's the 2 wires going to the on off switch - there are 3 screws, 2 next to each other and a 3rd below in between. not sure about the wiring of the 2 red wires and the schematic doesn't help.Comment
yes, I'm talking about the handlebar mounted emergency on off switch that houses the starter button...Comment
The two screws right next to each other hold the wires for the kill switch The third screw in the mounting screw for the kill switch assembly on top of the controller.
PatrickThe glorious rays of the rising sun exist only to create shadows in which doom may hide.
XS11F (Incubus, daily rider)
1969 Yamaha DT1B
Five other bikes whose names do not begin with "Y"Comment
Shouldn't there be 4 wires? Red/whites complete the hot circuit and a black and blue/(black or white) complete the start or ground circuit. I remember not to get the mixed up because you melt the button (if it's plastic) pretty damn goodJosh Yoquelet -- I'm having dreams of my XS
'79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
'79 XS11SF "bobber"- Rotted in a pine tree for 10 years
'81 Air forks w/23,000 miles
New steering head races and bearings
'78/'79 standard wire harness
Drag bars, w/Mikes controls
T.C.'s fuse block
PNM Coils
7mm Dyna Wires
NGK Resistor Caps
Custom 1" clutch and 9/16" MC
http://xs11bobber.tripod.comComment
