Has anyone used these on an XS11? These are from Mike's XS and are for the 650. Does anybody know what size bars the 650 has? These are very reasonably prices as compared to BikeBandit.
Right hand control
Right hand control
78 XS1100E Standard
Coca Cola Red
Hooker Headers
http://i408.photobucket.com/albums/p...m/DSC00580.jpg
1979 XS1100 Special
http://i408.photobucket.com/albums/p...m/DSC00612.jpg
1980 XS Standard
http://i408.photobucket.com/albums/p...m/DSC01137.jpg
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpgTags: None -
Just about every UJM has the 7/8" bars. I have not heard of anything but a Hardley that uses anything else (1" bars). What item are you looking at? A link, perhaps?1980 XS850SG - Sold
-H. Ford -
Forgot to add the pic
Here is what I am wanting to use if they will work.
78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
http://i408.photobucket.com/albums/p...um/warrior.jpgComment
If you're not going for the stock look, you can easily upgrade to controls from a modern bike. It is a pretty simple re-wire and with really nice usability. They are also readilly available and cheap.'81 XS1100 SH
Sep. 12th 2015
RIPComment
Hi Dale,
that switch will work on an XS11 but the wires won't be the same.
Mikes killswitch also has a "lights on-off" switch so there will be two more wires in it's pigtail. Nothing that a multi-meter won't sort out for you though.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Light On/Off
I did not think about the light sw Fred but maybe I'll put a Siren on it and use this switch to activate. Even better, I can use this switch for the "Silent Mode"!!
78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
Hey Foreda: I have one on my bike, they have 2 styles - one with & without the switch. I used the one without the switch - less junk. The wiring is pretty easy - just take your time & wire in to the existing one. Hell if I did it anyone can. Oh & they work great. I also had an xs650 & used the same new switches for it & they also worked fine, of course they just pluged right in. F.Y.I. I also used there other one for the lights on the other side & its working fine. The xs650 bars are 7/8's just like ours on the xs1100. Its great to have new controls - no worries. - Dan'81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
1179 big bore kit, 80SG motor
Rebuilt head, valves
TC Bros Forward Controls (Brass Pegs)
Tkat Fork Brace
T.C. Spade Fuse Box
Dyna Coils & wires
Mikesxs shocks,controls,& bars (special)
ISO grips with stelleto ends
4 into 1 black Bassani exhaust
Bridgestone Spitfires
Tuned by Tinman905
& a will to keep it.Comment
Switches
Thanks for the info Dan!!Hey Foreda: I have one on my bike, they have 2 styles - one with & without the switch. I used the one without the switch - less junk. The wiring is pretty easy - just take your time & wire in to the existing one. Hell if I did it anyone can. Oh & they work great. I also had an xs650 & used the same new switches for it & they also worked fine, of course they just pluged right in. F.Y.I. I also used there other one for the lights on the other side & its working fine. The xs650 bars are 7/8's just like ours on the xs1100. Its great to have new controls - no worries. - Dan78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
I had to just cut the plug off my harness and crimp on new male spades to fit into the female spade 4 wire plug on the switch without the lights. It works good and I haven't had any problems yet. I haven't wired up my left controls yet, but they don't look much harder other than they aren't plug and play also.Josh Yoquelet -- I'm having dreams of my XS
'79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
'79 XS11SF "bobber"- Rotted in a pine tree for 10 years
'81 Air forks w/23,000 miles
New steering head races and bearings
'78/'79 standard wire harness
Drag bars, w/Mikes controls
T.C.'s fuse block
PNM Coils
7mm Dyna Wires
NGK Resistor Caps
Custom 1" clutch and 9/16" MC
http://xs11bobber.tripod.comComment
