new Harley Slip ons
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    I made my cut just before "C" but I did it on standard pipes. Back when I did this on a special, I cut in the same place but I had to slit the end of the pipe and roll it down to fit into the HD muffler.
    I have a set of rusted up pipes cut the same way, I'll have to get pix for you...
    Geezer
      • 8930
      Centerstand is held on by 2 bolts and a spring. While on the sidestand, take the center stand spring off first with a vice grips, then the 2 bolts.
      • Silent
        • 343
        • San Jose, CA
        You shouldn't need to remove the centerstand to do this little surgery. If the bike is on the centerstand when you do this, it will stay out of the way. I did find it easier to remove the pipes from the bike for the cutting and welding portions tho.
        Ray
        '79 XS1100 Special - An XS Odyssey <<-- Click it, you know you want to!
        '07 FJR1300
        • Geezer
          • May 2003
          • 2985
          I wouldn't consider cutting the pipes on the bike but I already had a new set of exhaust gaskets. A die grinder make's this a quick job.
          Geezer
            Hey Gary,
            If you find you need or just want new exhaust gaskets, NW Cycles has them in stock and for a fair price.
