Lockhart oil cooler bolt
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    Anyone have that bolt that mounts the Lockhart oil cooler to bottom engine case?
    This one snapped and Bikebandit doesn't show it, or it could be from an XS750/850 ....IDK
    Thanks
    MDRNF
    79F.....Not Stock
  • XJOK2PLAY
    • 2099
    • Skiatook, Ok.
    Chop...
    Member Bgrubb7 has the entire setup for sale (at least up til the 13th of this month. Says he has the bolt... might be worth a shot. Pic of it in the parts for sale forum.
    Bob
    2011 Kaw Concours 14 ABS
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      adapter Bolt
      It is sold, But that pic looks like the correct size. It is male and female double tapped (with different Thread Pitches no doubt)
      I guess I will have to make one. The damn thing is too thin walled on the male thread that goes into the block and it snapped coming out.
      MDRNF
      79F.....Not Stock
      • XJOK2PLAY
        • 2099
        • Skiatook, Ok.
        Man,
        Sorry to hear that, Chop.
        I was hoping maybe that would work out for you.
        I'll keep my eyes open for another one.
        Were you able to get the broken part out?
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          tapped out
          It came out with a reverse tap.
          Of all the XS11 stuff that I have 2ea of this is not one of them.
          The male shank that inserts into the block has a thru-hole from the factory that is too thin-walled after being machined. I suppose it was lock-tited as well 30 years ago...LOL
          Here's what it's supposed to look like
          Here's what 30 years of heat cycling can do to thin wall steel....
          MDRNF
          79F.....Not Stock
          • petejw
            • 2269
            • sydney australia
            Could you weld the bolt up
            to get you out of trouble til you
            find another 1.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              • 2074
              Might be along shot but i once had that cooler mounted on my bike and some hardware laying around.Will check through my stuff and let you know by tomorrow.
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                Thanks
                I appreciate that. Just PM me if you have one.....GRACIAS
                MDRNF
                79F.....Not Stock
                  • 2098
                  xschop, The union bolt your looking for can be found at: http://xjbikes.com/Forums/viewtopic/.../start=15.html The only difference is the head of the XS11 bolt measures 32mm and the XJ Seca Turbo measures 27mm to clear the smaller adapter plate. The machined shank dia. and length are identical as I have both sitting in front of me as We speak. Also the washer is the same. I'll be using both bolts on my bikes or I would gladly send you one. Good luck! HTH
                    • 2098
                    Oh, You'll want to scroll down to section "E"
                      • 2074
                      cant seem to locate that bolt i thought i had-sorry
                        Hey Chop,
                        In case you can't find one, I'm expecting another 3' threaded rod piece soon, and I can cut off a 1" section, and drill it with a 1/2" hole so that it would be a bit thicker walled, and you could then weld it to the remaining piece you have. OR, I could also send you a replacement THICK NUT that you could use to make one along with a longer 2" threaded rod piece. The only thing is the smooth section that is used to CENTER the plate. However, you have machine abilities, so you could probably lathe cut a section out of some pipe material, or make a sleeve even?? Let me know if you want this/these pieces.
