For those who mount their own tires
  • Elevener
    • 608
    • small town in TEXAS
    I really didnt intend this thread to go this way. And I know long time users of a forum get tired of the same old debates but thats the way it works everywhere.
    Now as to does this work, People who cant see it working you will never convince. Even though almost every big rig on the road uses it. If it works on superswamper tires ( infamaous for balancing issues) then it works, period. I have never tried it on a bike and BB's or airsoft pellets cost alot less.
    I guess I will try it when I can afford new tires, but maybe I wont bring it back up when I do.
    Trapped in time. Surrounded by evil. Low on gas.
    1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
      Wow.. are we all supposed to hold hands skipping and sing songs? lol. Is it that everybody is supposed to agree on every post? Seemed like a pretty tame discussion to me.. Sorry you feel this way.
      • psycoreefer
        • Feb 2008
        • 1557
        • Minden, NV
        Doesn't their web site say it doesn't work well on "wide" tires? Maybe I made that up, its been a while since I checked out their site, I found it was cheaper to balance them the old fashioned way.
        1979 xs1100 Special -
        My Bike:
        [link is broken]
        • rockhoundtx
          • Dec 2007
          • 11
          • Godley, TX
          #34
          Skipping and Singing Songs!
          I didn't know you liked to skip and sing songs.
          But I digress, I put them the Beads in and they smoothed out the high speed ride. I don't know if the wheels were balanced properly before, But THEY WORKED.
          Now what songs do you like to sing and where is all this skipping going on?
          Rock Hound
          79' Eleven Special
          • Elevener
            • 608
            #35
            Dont let me stop you! No, its just that a few want to say, that has been discussed before.End of discussion, Others want to say it doesnt work period with no experience just because they cant wrap their minds around it. Being new here I just hate to rock the boat.
            I can tell you it works on big truck tires, period. I dont know if it works on motorcycle tires, but why wouldnt it? I really just didnt want to pay a shop to mount my tires but neither did I want to have to take them somewhere to be balanced if I did it. So was curious what others did.
            quote from Geezer..
            "On the other hand I'd love to have another wheel truing stand again. I'd love to get back into lacing and truing spoke wheels... Back when I was turning wrenches every mechanic was expected to be proficient in this now it's considered a dying art..."
            Yes, it was an elementary requirement, Im sure with your talents you could fabricate a stand quite easily. Shoot I made one with just a few pieces of wood once!
            • Geezer
              • May 2003
              • 2985
              • Willamina, Oregon 97229
              #36
              I guess I'm lazy. I want one with the cones to lock the wheel in and the arms with the pointers. Maybe one day I'll weld one up if I can get or machine up the cones too...
              Geezer
              • b.walker5
                • Feb 2009
                • 1745
                • Invercargill, New Zealand
                #37
                Centrifugal force acts more on the heavy side of the wheel, pulling the heavier side farther from the center of rotation, not closer to.
                Sorry Ivan You are absolutely correct, but the centre of rotation is not the same as the centre of gravity, and the heaviest spot will always be closer to the centre of gravity.
                The misunderstanding comes from assuming the wheel can have a center of rotation other than that of the axle. The center of rotation is fixed at the axle
                Once again, Correct but in an out of balance wheel the centre of gravity does not match the centre of rotation, and rotates around the centre of rotation causing the imbalance and vibration. This site explains it much better than I http://www.freestudy.co.uk/dynamics/balancing.pdf , but it's suffice to say "I'm a believer" and many are not.
                When people sometimes ask why I ride a 30 year old Japper I often answer with "For those who understand no explanation is needed, for those who don't understand no explanation is possible" I guess this is the same thing
                • jmnjrpa
                  • Jun 2009
                  • 863
                  • Lewisville, Texas
                  #38
                  Sorry B. Walker,
                  Gravity is not the prevaling force here. If the tire is not going to be spinning it would. The term "center of gravity" describes force attributed to mass and is still not understood. On the other hand centrifugal force is fully understood and explanations are simple.
                  We are dealing with a multiple cause vibration when referring to "out of balance tires. There exists two seperate forms of "balance" often applied to spinning objects. The first is static balancing which several ways to address have been covered in this thread. The second is harmonic. The beads would dampen (as stated previously) vibration. This is not a true balance in reference to gravity or centrifugal force but rather an inhibitor that allows RPM to continue to increase. The dampening effect would in all likelyhood transform into less tire wear expecially on high pressure tires. The higher pressure promotes vibration. Nonetheless an out of balance or out of round tire will be pushed further out by the addition of the beads. That being said the best material for this use would be round lead split fishing weights.
                  '81 1100 MNS - "Midnight XSpress"
                  Original except:
                  Big John
                  • b.walker5
                    • Feb 2009
                    • 1745
                    #39
                    I would suggest that more reading is required... However you may want to disprove the theory, the fact is that in practice it works.
                    Agreeing to disagree
                    Brian
