thanks for all the thoughts. Still not running right. In idle runs great and low gear runs good but in higher gears starts loosing power. I have soloid the broken wire ohm on the pick up coil went from 610ohm to 720ohm. I have measured the volt on wires orange and gray got 12vdc. I replaced the coils and spark plugs because the reading where 25k on the spark plug wires 1 @ 4 and 2 @ 3where all over the place. Have more power but I am still find after 30min ride the exhust pipe on 1 @ 4 still warm to the touch and now it's started to back firing . thanks max
AGIAN THANKS LOTS FOR ALL THE HELP
