thanks for all the thoughts. Still not running right. In idle runs great and low gear runs good but in higher gears starts loosing power. I have soloid the broken wire ohm on the pick up coil went from 610ohm to 720ohm. I have measured the volt on wires orange and gray got 12vdc. I replaced the coils and spark plugs because the reading where 25k on the spark plug wires 1 @ 4 and 2 @ 3where all over the place. Have more power but I am still find after 30min ride the exhust pipe on 1 @ 4 still warm to the touch and now it's started to back firing . thanks max
AGIAN THANKS LOTS FOR ALL THE HELP
I have the bike running thanks to you guys. turned out to the TCI box. So I have used the gm ign. replacement but Idle seem to idle fast. What is normal settings for idle on rpms and do you adjust the idle speed knob when bike is warm up. I have also replaced the coils with the newer up grade. thanks again.
