What mods are on your bike?
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    Updated
    1980 XS1100SG
    K&N Airfilter (stock airbox)
    Mikes XS Hight Output Coils ($35 version)
    Mikes XS Yellow Performance Silicone Plug Wires
    160 MPH Speedo
    Removed Octy
    Added Fuel Filters
    Removed Badging on Side Covers and Tank
    Repainted Side Covers.
    Smoothed Out Tank and Painted
    LED Lights (added below tank for show)
    HID Headlight.
    T.C.'s Fuse Block
    DynoJet Stage 1
    In the works. LED Brake Light and Turn Signals, SS Brake Lines, TKAT Fork Brace
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
    • Paintman
      • Mar 2008
      • 312
      • rapid City SD
      Bike Mods
      79 Special,Cross drilled rotors, T-Kat fork brace,progressive springs front and rear .Galfer brake lines. Wiesco 1179 Kit , rebuilt head, Carbs ,750 Mod, Hi Per Coils 8mm wires, new boots, rear cargo rack KQ seat. and new paint
      79 XS1100SF 750 FD,Galfer Brake lines,ebc brake pads,Cross Drilled Rotors,TKat fork brace,bead blasted wheels repainted and polished
      80 XS1100 S Project gonna be a hot rod
      06 CBR1000RR sold!!!!!
      2000 Concours
      84 Kawi KLR600
      79 Yam XT500 Ouch it kicks back
      79 XR250
      Why is it that the smallest part can fly to the farthest part of the shop?
      John
      • 79XS11F
        • Jul 2006
        • 3563
        • Ottawa, Ont. Canada
        Other then Yamaha Factory engine case guards and a Plexi Fairing, The bike is Completely stock.
        1978 XS1100 E
        Wisco 1179 kit.
        Removal of internal and external kick start assembly
        Cer-Cycle High performance clutch & springs
        Polished and ported head
        NOS rod and crank bearing
        2nd gear washer fix
        Alloy engine mounts
        Oil pressure gage
        K&N POD air filters
        Chrome carb covers
        K&N engine vent filter
        Dial-A-Jet external fuel supply
        Dino jet kit
        Oil cooler with bypass
        RC Engineering headers
        Chain drive kit 11/36
        530 O-Ring Racing Chain
        Reinforced frame
        Accel coils & wires
        NOS pickup coils
        Driving lights
        HID head light
        Duel blaster air horns with relay
        Alarm
        Low handle bars
        Gel grips
        Square mirrors
        Progressive fork springs
        Air fork kit & gage
        Daytona fork brace
        Steering damper
        Progressive shocks
        SS brake lines all round
        Pro-lite Rotors all round
        Pro-lite Pucks all round
        All balls bearing all round
        Engine case guards
        Magnetic oil pan drain plug
        All SS socket head hardware on rolling chassis
        Self adjusting cam chain tension adjuster
        Custom painted wheels, handlebar controls, callipers, master cylinders, levers & perches
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
          Swapped in parts, mostly. Standard tank (needed more range)
          Standard 'trees (needed less trail) MPH speedo from an XS650 (the metric stocker died, this one was to hand)
          CB750 'bars.
          The only true "modification" was to install UNIpod air filters. (too much blood loss removing stock airbox)
          Last but not least, installed Stebel-Nautilus 139dB air horn.
          (Oh boy, they may not see me but I can surely be heard!)
            • 6764
            Short list for my'82 XJ1100
            K+N Pod filters
            Jardine 4 to 1 exhaust
            3 point case guards with hwy. footpegs
            reworked stock seat and extra seat pad on top
            TC made fuse holder with the plug in fuses
            Adding(again) Vetter Windjammer with lowers
            new foam and chrome handgrips with throttle rock it
            rejetted carbs to match the exh. and pod filters
            replaced orig. gearsets with new factory backcut ones
            had engine repainted all one color
            2005 Honda SilverWing 600
            2018 Honda PC-Xpress 150
            • barberad
              • 416
              • the 45th state
              82 XJ
              Ghost Flame paint job
              Jardine 4-1
              Knock-Off K&N's
              Givi Flyscreen
              Hwy pegs
              Seat Pad/sissy bar
              4 speed transmission Haven't gotten to the 1rst gear fix
              Current Rides: '82 XJ w/Jardine 4-1's, GIVI flyscreen, '97 Triumph Trophy 1200
              Former Rides: '71 CB350, '78 400 Hawk, '75 CB550/4;
              while in Japan: '86 KLR250, '86 VT250Z, '86 XL600R, '82 CB450(Hawk II), '96 750 Nighthawk, '96 BMW F650
                Just the basics,
                Vetter Tour package (fairing bags and trunk)
                Jardine Spaghetti 4-2 w/turnouts
                LED Tail lights
                Electronic Flasher
                Some aftermarket seat of some sort, with flakey PO installed cover.
                Blade Type Fuse Box
                • 81xsproject
                  • 3185
                  • Fortuna, CA
                  I don't think I can remember them all, but I will hit the highlights.
                  -Megasquirt II v3 Engine Management System
                  >'02 GSXR Throttle bodies
                  >GM DIS Ignition System
                  >AEM Wideband O2 Sensor
                  >'99 Hayabusa external fuel pump
                  -8mm Accel plug wires
                  -70's Intake Cam
                  -Hydrolic Clutch
                  -CBR F4 Brake Master
                  -Modern controls
                  -Bicycle cammed seat bolt mod (in progress)
                  -lots of other little stuff
                  '81 XS1100 SH
                  Sep. 12th 2015
                  RIP
                  • daveyg
                    • Feb 2009
                    • 411
                    • Boise, ID
                    -70's Intake Cam
                    -Hydrolic Clutch
                    -Modern controls
                    Lets see a pic of this frankenstein!
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      Feel free to click on the links in my signature to see some of the mods. The bike is actually ugly as hell right now from oil leaks and a disasterous master cylinder leak. However, like all build stories, you start from the engine up.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
                      • Bigfoot
                        XS-XJ GURU
                        • Sep 2005
                        • 1422
                        • Kansas City, Missouri
                        1980 MNS
                        K&N filter
                        850 final drive
                        2nd gear washer swap
                        Krauser hard bags
                        Blade type fuse block
                        Clubman handlebars with setback risers.
                        Stainless brake lines
                        XJ rear shocks
                        I think that is about it.
                        Harry
                        '79 Standard
                        '82 XJ1100
                        '84 FJ1100
                        Acta Non Verba
                        • mooseman
                          • Jun 2007
                          • 28
                          • Pocono Mtns, PA
                          Mods
                          Wow you guys make me feel bad. The only thing I've changed on my 79 XS1100 Special Are the front brake lines to Galfer and later discovered I really did not need them (it was the master brake cylinder and calipers that needed rebuilding.) Everything else is 100% stock including the original Yamaha Windshield. I did recently add a sidecar to extend the riding season with my wife (She likes to bundle up). I am the orginal owner and the bike now has 39,001 miles on it. Mooseman
                          79 SF
                            Thunderstruck has;
                            Drilled rear baffle plates
                            750 Final Drive
                            Blade type fuse box
                            No more Octy
                            King/Queen seat
                            Soon to come;
                            SS brake lines
                            Auto adjusting cam chain tensioner
                            Hopefully some CB750 or Goldwing handlebars
                            • ManitoulinLad
                              • 358
                              • Manitoulin Island,Ont.,Canada this is in Lake Huron
                              Here goes: 1981 XS1100 LH
                              Mikes coils (black $35 ones)
                              xs performace yellow leads & plug ends
                              iridim plugs
                              tc fuse box
                              mikes xs super bright blue head light bulb
                              mikes buck horn bars - BBB shot filled
                              mikesxs chrome handlebar cover that holds bars on bike
                              Kirykan black & silver grips with the stelleto ends
                              Chrome mirrors with gold accent highway hawk saying...
                              Tkat fork barce
                              Mikesxs shocks
                              mudflap on front tire (leather black)
                              4 into one exhaust (think its a mac - black)
                              1179 bore out kit with heads & valves all redone
                              TC Bros forwards with brass pegs to match the black & gold
                              Headlight visor
                              seat & original back rest recovered with marine grade vinyl with the buttons in it - black
                              tip over switch, headlight reserve light switch & octy removed
                              2 in-line fuel filters (the brass cone shaped ones)
                              painted xj motor & tranny etc all shiny black
                              xj motor has the magneto type charger
                              best mant free battery i can buy (something like yuma i think)
                              separated brake lines - front is on its own & so is the back - not linked
                              mikesxs chome controls for signals & start switch
                              I think thats it for now
                              - what I would to still do is upgrade the coils to mikesxs green ones, I might make the exhaust a 4 into 2 with 30" long fishtail exhaust with steel baffles. I have an excellent complete original & looks new xj exhaust double walled 2 into 2 to be able to do this. But that 4 into one does sound great though. eventually I might go with the progressive springs on the forks.
                              - Dan
                              '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
                              1179 big bore kit, 80SG motor
                              Rebuilt head, valves
                              TC Bros Forward Controls (Brass Pegs)
                              Tkat Fork Brace
                              T.C. Spade Fuse Box
                              Dyna Coils & wires
                              Mikesxs shocks,controls,& bars (special)
                              ISO grips with stelleto ends
                              4 into 1 black Bassani exhaust
                              Bridgestone Spitfires
                              Tuned by Tinman905
                              & a will to keep it.
                              • Ivan
                                • Jul 2008
                                • 2524
                                • Hutchinson KS
                                I have an 81 special with an 80 standard engine, an 80 MNS frame, a 79 rear disc, XJ shocks, Kury goldwing grips, black tires, and some spray on fake road grime.
                                Ich habe dich nicht gefragt.
