Front Fork Woes
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    Front Fork Woes
    So after the third set of fork seals this season and new bushings , one seal is still leaking a lot .There was fluid on my brakes today on the test ride . Time for different forks ?
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • 8795
    If you go with the progressive springs, you won't need air anymore, and you can use the Leakproof Seals. Just a suggestion.
    • Axel
      • May 2007
      • 869
      • Renfrew,Ontario
      Hey
      Hey Phil . I have the progressive springs (no air) and I've used 2 or 3 different kinds of seals .
      All-balls red seals ,some black seals and red seals from XJ4ever (which I think are the same as All-balls) . Inner and outer bushings have been changed as well .
      XJ1100K
      Avon rubber
      MikesXS black coils
      YICS Eliminator
        • 8795
        I've used the Leak Proof brand before on pitted tubes and they stopped the leaks. They were first designed for motocross applications, then developed for street bikes. They are flexable and don't need to be driven in like a conventional seal. Dennis Kirk has 'em. They're about $20 American for a set.
        • snowdog51
          • May 2006
          • 348
          • st. paul ,mn
          forks
          fj forks dropp right in just 1 7/8 inch spacer nice brakes nice handling
          bill hane
          • xs11bobber
            • Jun 2009
            • 229
            • Cromwell, Indiana
            Can you replace just the springs to do this conversion? I just bought some air'd on eBay, but I'm a little worried about when they start leaking.
            Josh Yoquelet -- I'm having dreams of my XS
            '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
            '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
            '81 Air forks w/23,000 miles
            New steering head races and bearings
            '78/'79 standard wire harness
            Drag bars, w/Mikes controls
            T.C.'s fuse block
            PNM Coils
            7mm Dyna Wires
            NGK Resistor Caps
            Custom 1" clutch and 9/16" MC
            http://xs11bobber.tripod.com
            • GARTHXS
              • Nov 2007
              • 1631
              • Seattle
              spacer
              Where does the spacer go?
              91 kwaka kz1000p
              Stock
              ( Insert clever quote here )
                • 8795
                Replacing the springs with the Progressive ones will eliminate the need for air, but your seals still have to be in good condition or you're gonna have fluid leaks. The ride is much better with these springs IMHO. I'm running them in both my 11's.
                • WMarshy
                  • Apr 2009
                  • 2402
                  • Mexico NY
                  Replacing the springs with the Progressive ones will eliminate the need for air...
                  Phil, to my understanding the 79's didnt have air forks unless they were specials...? Is this correct? I have been wondering about the progressive springs for mine and was wondering if they are different springs beteen the two types... Can you clarify please? Thanks.
                  '79 XS11 F
                  Stock except K&N
                  '79 XS11 SF
                  Stock, no title.
                  '84 Chevy K-10 "Big Blue"
                    • 8795
                    You are correct. The 78-79 Standards were not air forks but the 80 and up's are air type. All the Specials are air type forks. The Progressive springs are the same for all the XS11's, Standard and Special. The Specials require a 3.5" spacer on top the springs which is included in the kit, Standards (all), no spacer.
                      Hi Axel,
                      and don't you just go sliding on when your brake pads get oil on them?
                      Got me a right forearm just like Popeye's from that.
                      OK, the seals I changed were most likely the one's that the bike had from the factory but if your new seals are leaking, check the fork tubes.
                      Any surface defect in the fork tube that's big enough to see or feel will chew at the seal and make it leak.
                      If you find such a flaw, replacing the tubes is the only answer. Or as you say, swapping in another fork.
                      • Axel
                        • May 2007
                        • 869
                        • Renfrew,Ontario
                        One more time - pls
                        Got another set of forks on the way. Polished the cr@p out of the pitted tube with crocus cloth then Autosol . Then I waxed it ??? Anyway after my holidays in NS I will be ready to confront this problem again . I just think I'll sneak out for one last ride - ok maybe 2 .
                        I cleaned the brakes off with carb cleaner and re-adjusted the pinch bolt . Seems the disc was touching the caliper !!!
                        XJ1100K
                        Avon rubber
                        MikesXS black coils
                        YICS Eliminator
