Cam Chain Adjuster
  • Nick7777
    • May 2012
    • 121
    • Michigan, U.S.A.
    any of the r1 or r6 cct ever work by chance
    80 MNS; 81 Venturer
    • Tat2demon
      • Jun 2012
      • 718
      • Sioux Falls, South Dakota
      Theres a full list of ACCT that fit here.
      I just got one last week that was off a 2001 Raptor for $9, express shipping included.
      Nate
      78 XS11 "Matilda" 2H7 000364
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
      • Nick7777
        • May 2012
        • 121
        • Michigan, U.S.A.
        thanks a lot man. just turned the bike over and noticed that wasn't there, my first bike and i have to put it together as well. im guessing its out of time now....
        80 MNS; 81 Venturer
        • Tat2demon
          • Jun 2012
          • 718
          You don't have a tensioner at all? If it hasn't skipped some teeth and taken out your valves Id be surprised.
          Nate
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
          • Nick7777
            • May 2012
            • 121
            • Michigan, U.S.A.
            correct, i turned it over, no gas in it so it didn't fire, just wanted to ensure the motor wasn't seised up.
            80 MNS; 81 Venturer
            • WMarshy
              • Apr 2009
              • 2402
              • Mexico NY
              What Nate's sayin is, if there is no tensioner in the engine then there is a very high probability (~99.9999%) that you wrecked some valves, even if it didnt fire... no tension on cam chain = no cam rotation = valve to piston contact = bent valves. I think you may have a big problem on your hands...
              Did you take the tensioner out of the engine? Do you know where is is located or know what is looks like? Im not being rude just dont want to build anxiety or send you on a wild goose chase because you dont know what/where the tensioner is...
              In order to see if you have any bent valves your going to have to reset the cam/crank timing. First, do not rotate the engine anymore until you do the following. Take the valve cover off, loosen all the cam journal caps and remove the cams so all of the valves are unloaded, turn the engine with a wrench to set the crank to the "C" mark under the left cover (remember to turn clockwise as imprinted on the little wheel). Reinstall the cams (I suggest following the manual on torque sequence) and install a cam tensioner! Then check compression and report back here.
              I suppose you could check the alignment dots on the cams to see if they line up but if there truly is no tensioner in the motor when you turned it over then there is no value in checking this... Good Luck!
              You might want to spend some time on here reading and searching for tips especially when it comes to engine work or you could get in over your head real quick. All the mistakes have already been made and documented on here.
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
              '84 Chevy K-10 "Big Blue"
              • WSL91
                • Feb 2012
                • 427
                • Quad Cities, IL
                Exactly, Raptor CCTs are plentiful and cheap, why re-invent the wheel? Just bought 2 and installed for around 20.0
                1970? Honda Z50... gone
                1974? Yamaha 100 Enduro... gone
                1974 Honda CB200... gone
                1981 Yamaha Virago 750... gone
                1993 Honda Shadow 1100... gone
                2008 Honda VTX 1800F
                1982 Yamaha XJ1100J w/850 final, Raptor ACCT
                1979 Yamaha XS1100SF "Chewey" Raptor ACCT
                http://www.johnsoldiron.com
                • Nick7777
                  • May 2012
                  • 121
                  • Michigan, U.S.A.
                  WMARSHY, I usually work on cars, and no i did not remove the CCT(last thing i would have looked for since it had pipes and everything already installed). I had bought the bike about two months ago and the PO said that a bike shop in his town had went through the motor and did a couple thousand dollars worth of work... some mechanics if they can't put somthing as simple as this on. thanks for the advice and i'll let you guys know if i screwed the pooch or not.
                  80 MNS; 81 Venturer
                  • WMarshy
                    • Apr 2009
                    • 2402
                    • Mexico NY
                    Wow, some mechanic! If you get in a bind or have questions dont hesitate to ask. Try a quick search first, you'll be amazed how many hits you'll get that suits your exact question/problem. And ifyour your looking for replacement valves, I know one member has a full set left from having some aftermarket ones made... I think he's only willing to sell the entire set not individually.
                    '79 XS11 F
                    Stock except K&N
                    '79 XS11 SF
                    Stock, no title.
                      If a new cam chain was in that couple thousand dollars work, you're probably in luck. I just changed mine and it was pretty tight. So, if your chain is new it may not have fallen off the crank sprocket. If the chain isn't new, I concur. The crank rotated and not the cams.
                      • WMarshy
                        • Apr 2009
                        • 2402
                        • Mexico NY
                        Interesting ... it might be worth check the alignment dots on the cam to the C mark on the crank timing plate then before you go taking the cams out then. You have to remove the cam cover still.... no biggie.
                        '79 XS11 F
                        Stock except K&N
                        '79 XS11 SF
                        Stock, no title.
                        • GLoweVA
                          • Jun 2011
                          • 1957
                          • Virginia Beach, VA.
                          The dots line up when on the T mark.
                          80G (Green paint(PO idea))
                          The Green Monster
                          Got him in '04.
                          bald tire & borrowing parts
                          Scarlet
                          Got her in '11
                          Ready for the twisties!
                          81H (previously CPMaynard's)
                          Hugo
                          Cold weather ride
                          • Nick7777
                            • May 2012
                            • 121
                            • Michigan, U.S.A.
                            and i have read some talk about cleaning the excess material off the pin so that it matches the stock length, is there a set dimension for the 81 motor, i read somwhere that the cams are different over the model years and would hate to shoot myself in the foot even further than i may have already.
                            80 MNS; 81 Venturer
                              Don't take anything of the plunger, you get more length with the acct's thus longer between chain changes.
                              • Nick7777
                                • May 2012
                                • 121
                                • Michigan, U.S.A.
                                oh, thanks for the advice. and now just to wait for the mail man to bring it. any altering of the raptor acct needed.
                                80 MNS; 81 Venturer
