If anyone else has come up with this or heard about it, I haven't. As many of you know, Bohn Fraser had some problems with his adjuster that ended up with some bent valves. He took it to a mechanic that has built hundreds of these motors for legend racers.
When he was through, he installed an adjuster from an FJ1200 motor. It doesn't fit EXACT... but close enough to work. This adjuster is longer and resembles a phallic symbol a bit.. but who really sees it? AND... this adjuster is automatic and ratcheting! That means no adjusting.. EVER! If you ever start hearing a lot of cam chain noise, it means that you have stretched your chain beyond the limits and need a new one. Bohn said he never heard any cam noise on this last trip to Colorado. I had to adjust mine on the way home in a 90+ degree parking lot. Plus.. no set screws in the side to leak oil.
There is a downside though. This adjuster will work on an XS... but not an XJ. The XJ has an extra bar across the front for frame stiffening that goes right in front of this adjuster and it won't work. Anyway.. I thought it was a great idea and thought I'd pass the info on...
![](http://i30.photobucket.com/albums/c337/trbig/Camchainadjuster.jpg)
