Oil Cooler adapter installation
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    I have an oil cooler for my bike that makes use of an adapter disc that goes between the oil filter bowl and the engine. The hoses come off the front of this 1 inch alloy disc. It gets attached with a steel bolt that the oil filter bowl bolt will thread into. This may even by a factory setup. I don't know.
    Question, I am guessing that the adapter disc bolt should only be torqued as much as the filter bolt so what prevents both the adapter bolt and filter bowl bolt form coming out together during filter changes?
    Should I perhaps be using lock tight on the adapter bolt?
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    IIRC, we put RED locktight on the adapter bolts to try and keep them in the bike.
    • oseaghdha
      • 1075
      • N43.02.5,W88.14.2
      I have the same setup, but I only get one long bolt.
      XS1100SF
      XS1100F
      • 79XS11F
        • 3563
        OK, so red lock tight it is on that bolt.
        Any reason why I can't or shouldn't install a heat activated flow valve with this cooler set up?
        Rob
        1978 XS500E
        1981 Suzuki GS1100
        • tw1980
          • Apr 2009
          • 662
          • Bend OR
          Sounds like a good idea Rob.Mine has the same setup.Where do you plan on placing the valve?
          Terry
          1980 special (Phyllis)
            Hey Rob,
            Maximan installed a B&M cooler and used their 180 degree thermostat,
            Thermostat valve 70259
            See this page for photo, and PDF installation instructions.
            http://www.bmracing.com/PRODUCTS/Coo...-Control-Valve
            It provides a bypass function until the oil gets to temp, then routes it thru the cooler. A bit pricey. Also, depending on what type of hoses and fittings you have, will probably need to use some form of adapters!?
            • 79XS11F
              • 3563
              The valve I have is from a Lockhart oil cooler that was damaged when the bike fell over. I will hook it up down low where there's lots of space for it.
              Thanks for the input guys
              Rob
              1978 XS500E
              1981 Suzuki GS1100
              • wa407mpp
                • Jul 2007
                • 717
                You might want to mount up as high as possible, it's not something you would want to get hit by a piece of gravel thrown up by your front tire. Those two mounting holes for the fairing mounts on the frame uprights is a good mounting point.
                Fastmover
                lion". SHL
                78 XS1100e
                • 79XS11F
                  • 3563
                  It will be above the lower edge of the fender but not high enough to get in the way of cam chain adjustments. There's not really a lot of room there given that the cooler supply hoses need to be away from the headers.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • wa407mpp
                    • Jul 2007
                    • 717
                    This is where I was talking about.
                    Fastmover
                    lion". SHL
                    78 XS1100e
                    • 79XS11F
                      • 3563
                      OH, the cooler itself, yes it is right up at the top. The valve will be down lower
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • 79XS11F
                        • 3563
                        On these adapter disc's which holes are considered to be OUT to the cooler and IN from the cooler. There are 2 holes in the disc. 1 into the filter bowls space and one into the new chamber that is above the disc when its installed.
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • 79XS11F
                          • 3563
                          Bump ... New question on cooler hook up
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                            Rob,
                            The hole that goes into the filter bowl will be the IN from the cooler, the other hole will be the OUT to the cooler. The plate sends the oil out to the cooler first, then comes back into the plate, then down into the filter cup and eventually up into the engine.
                            • 79XS11F
                              • 3563
                              Rob,
                              Thanks TC.
                              I needed that info so I could get the cooler installed.
                              Rob
                              1978 XS500E
                              1981 Suzuki GS1100
