Hello!
I'm in the process of purchacing an 81 1100 Midnight Special. I have limited experience fixing motorcycle engines, but I think the problems this bike has are simple to fix.
The previous owner took very good care of the bike and stored it in his basement... but the current owner left the bike outside under a roof, with no walls all winter. During this time, the pipes were removed - so although no rain had landed anywhere on the bike, there was very high humidity. (Live on an island where only 4 weeks of snow in winter - the rest is rainfall)
The body and engine look mint.
Looking from the back of the bike the two right cylinders do not fire. All four plugs have spark. The current ownder has done almost nothing to correct the problem and wants to sell it.
I told him that as long as there is no rust in the engine, I will buy it.
I assume its two gunked up carbs, possibly all four have some gunk.... Could this be a bigger issue? If it might be expensive fix I do not want the bike. However, if all I have to do is remove and clean the carbs or change a couple gaskets, I will buy the bike.
All info/advice appriciated!!
Adrian
Adrian
All of the electrical seems to be in great working order so far. I also broke a bolt holding the seat in place.... righty tighty, lefty loosey LOL. Not sure what I was thinking.
