looking for the correct carb sync procedure
  • EXXXCESS
    • Mar 2009
    • 46
    • greene county ga
    I am trying to find a link to the correct carb synch procedure
    79 XS 1100 Special
  • oseaghdha
    • Aug 2006
    • 1075
    • N43.02.5,W88.14.2
    Try this
    XS1100SF
    XS1100F
      Here is a link to another thread with a video of the process I found.
      • greatnw
        • 177
        I do have a question about the vacuum advance port on #2. I pulled the vacuum advance line and plugged it while syncing. Correct?
        Bothell, WA
        1980 XS1100SG
        • Ken Talbot
          • 4251
          • Revelstoke, BC
          You want to leave that one connected and working properly. This is the line connected to the nipple on carb #2, which operates the advance mechanism.
          Ken Talbot
          • greatnw
            • 177
            Thanks Ken.
            Bothell, WA
            1980 XS1100SG
            • RUSH
              • Feb 2005
              • 214
              • Lake Stevens, WA
              Does anyone have an opinion about using blue locktite on the sync screws? I synced my carbs and the bike was smooth as silk, but after a 20 min ride on the freeway I find a slight vibration at 3.5-4k rpm. I was thinking of rechecking the sync and if it has changed, readjust and drip a little blue locktite on the screws to keep them from turning on their own.
              First bike was an: 1978 XS1100
              Second bike is an FJR1300.
              Now I'm restoring a '79 XS1100.
                • 8716
                A slight vibration shouldn't move those screws any. Try to find the source of vibration, maybe loose exhaust. I wouldn't use any thread locker, JMHO.
                • John
                  • 5117
                  The springs that are on the throttle linkage and adjusting screw is intended to keep the screw from vibrating loose by keeping tension on the screw, preventing it from turning.
