I just had the best day on my xs then....
  • oseaghdha
    • 1075
    • N43.02.5,W88.14.2
    That's a lot of trash on that screen.
    Sounds like you smoked a piston and took out a rod.
    Pretty much boat-anchored it.
    XS1100SF
    XS1100F
    • petejw
      • 2269
      • sydney australia
      Spun big end bearing
      I finally got the lower case off, ( i didnt undo the 2 bolts under the oil filter), and discovered number 2 pistons big end bearings top half had spun under the bottom half bearing resulting in the engine seizing, also piston 3's big end bearing had worn and was tight on the crankshaft.
      This was caused because of fuel leaking from the carbs and into the engine, none had leaked back thru the air filters, so i wasnt aware of it til i drained the oil and 5lts drained out.
      So at this stage Im up for a crankshaft, a con rod and bearings, so not to bad after all.
      below are some pics.
      no2 piston spun big end bearing
      close up crankshaft
      crankshaft
      no 3 piston and bearing
      pic of the mess in the garage,
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • petejw
        • 2269
        • sydney australia
        Bearings
        The good news i rang yamaha and they have the
        bearings in stock,
        the bad news is that they want $40 for each half bearing, totalling
        $320, if i want to replace the crankshaft bearings im up to nearly $600.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
