Service manual.. per rebuild installation procedure in quotes.
As per paragragh one... in order...
"He put the timing on mark on the C"
"...removed the tensioner, pushed the plunger in all the way..."
"...re-installed..."
"...loosened the set screw and heard a "click", "
"...then tightened it down."
Any verbal abuse you may have felt may be due to you coming on here and starting off sounding like a pompous azz, when it seemed pretty obvious to everyone that you really have no clue of what works and what doesn't with these bikes.. at least when it comes to the adjuster or cam installation/removal. While I will admit that I have never seen the part about actually pushing the plunger in all the way before installing it for an adjustment, I had only heard of doing from on here. This certainly does not "put undo stress on the chain" as you stated. If you would take a motor or two apart, you'll also find that the book isn't right in several places on procedure or sequence.. but in this case, I'm really not sure what it is you're getting at or why you keep posting, other than to be a PITA.
While the proper procedure for adjustment is to simply loosen the set screw, you will not hear any "Click" that way, so most people remove the tensioner and follow the procedure for installation to be sure they are getting the plunger against the adjuster bar. The reason Bohn removed his tensioner was because he had a small oil leak out of the tip which had previously been fixed, and he was trying to keep the couple drips of oil off his motor so he could continue to be able to eat off of it if desired.
I was told by a moderator yesterday to ignore your comments and let sleeping dogs lie... but aparently that isn't possible. I doubt even this will be the final say. BUT... if you have something of value to add, this is an open forum.
6. Rotate the crankshaft approximately 45* and align the "C" mark on timing plate with the timing pointer.
7. Compress the cam chain tensioner and lock in the retracted position.
8. Install the chain tensioner to the engine and torque the bolts to specification.
9. Release the tensioner holding bolt, an audible click will be heard when the tensioner is released.
10. Torque the holding bolt and lock nut to the specifications.
