are you sure ole Cody on that silver bullet wasn't just stroking along on a Rocky Mountain High site seeing as that C-14 of his is pretty stout
Don't get me wrong.. in the straights he whips me like a red headed step child. Nearly twice the HP will tend to do that. BUT.. in the twisties, I'm just a bit dumber than him I guess..
) I have found that if you line up the timing at the "T", with both cams on the timing marks, the problems go WAY down! You WILL need to SLOWLY rotate the crank to the "C" and reset the tension on the adjuster after you are done. This is what I found to keep the valves and pistons from trying to mate...
(harley) mechanic. He cleaned around CCT and found small crack in barrel above CCT where bolt went in. fixed, no more oil leak
