frame rake
  • cowboybob998
    • Mar 2009
    • 371
    • KC MO
    frame rake
    Does anyone know if there is a deferencs in the frame rake on a standerd and special
    1979 xs1100 f
    142 main, 45 pilot, Jardeen crosover 4/2, no air box
    floats @ 25.7
    1979 xs1100 F
    1978 gl 1000 goldwing
    1981 gl 1100 goldwing
    !986 venture royale 1300
    Just an ol long haired country boy, come to town to spend some egg money
    when ya get bucked off, get back on
    • 7831
    NO, the only difference is the triple tree.
      They are both the same Rake = 29.5 degrees. As DiverRay mantioned, the only difference is the trees, which change the Trail between the Standards and Specials.
      • cowboybob998
        • Mar 2009
        • 371
        • KC MO
        Was thinking about putting a special front end on a standard to get a longer wheelbase, get in trouble when i sit around and think to much, lol
        1979 xs1100 f
        floats @ 25.7
        1979 xs1100 F
          Whoa, boys - - -
          Hi Bob, Ray, 'Bug,
          Let's be clear about this whole thing.
          Specials and Standards have identical 29.5º rake and 5.12" trail.
          They are cosmetically different in that the Standard carries it's front axle at the bottom of the fork sliders
          while the Special carries it's front axle on the front of the fork sliders and has shorter 'trees to keep the trail the same as a Standard.
          If you swap in Standard 'trees on a Special yes you will get a longer wheelbase.
          You will also get less trail and hence, lighter steering.
          XS11 sidecar operators like myself and others have made this swap to lighten our rigs' steering.
          Making the swap on a solo will of course lighten it's steering also.
          Which can be OK if you are expecting it but perhaps not if you ain't.
          • cowboybob998
            • Mar 2009
            • 371
            • KC MO
            Just going for the look, use to ride them ol choppers years ago, cant be any worse than that, besides i think a little longer wheel base rides better, just thinking out loud, never know what i will do, lol
            i am like the gov. i am gona fix it untill its broke
            1979 xs1100 f
            floats @ 25.7
            1979 xs1100 F
              Swappin' around
              Originally posted by cowboybob998
              Was thinking about putting a special front end on a standard to get a longer wheelbase, - - -
              Hi Bob,
              yeah, you can swap in a Special's entire front forks and fender (the fenders look the same but they bolt up different) onto your Standard to get the longer look but you will be stuck with the Special's Weird Harold front brakes.
              Doing this will not change the wheelbase or alter the steering apart from whatever handling changes that may be caused by the differences in the fork internals.
              Keeping the Standard 'trees while you do this will give about 1½" longer wheelbase and also quicken the steering.
