If you ask me (which I know you didn't but your gonna get it anyway
)If you do anything to increase the fuel presure to that extent, your going to most likely over power the float seat valves and or floats and shove to much fuel into the bowl which will work like having bad float needle valves dumping fuel into the engine, the air box, and making the bike so rich you would lose all power and foul out the plugs. JMHO For a running bike, it sounds like a loose loose situation to me.
). they don't call it a "fuel dump pump", but an auxiliary fuel pump. and it does throw a good bit of fuel into the mix @ WOT. so I'm sticking with my original theory, it's part of an NO2 system, you don't need it on your XS unless.....
