anyone ever installed a fuel dump pump on one of these bikes......and whould i need to rejet....just wondering
fuel dump pumps.....
1980 gs1000g "stock"
2008 jmstar 150cc Chinese scooter ( wife's bike)Tags: None -
well i herd it from a friend who had one on his 92 gsxr 1100 (prevoisly installed buy prievouis owner)...... he told me it like a fuel pump but only engages on WOT.... and when it its WOT it just dumps a crap ton of fuel into the carbs...._____________________________________________ 1979 XS 1100 Special "The judge" mods- K&N air pods, 4-1 mac, 147.5 pilots, 57.5 mains, LED turn signal, cafe bars, HEL translucent yellow stainless steel brake line, dyna coil (dc2-1), raptor 660 mc, r6 controls..(sold)
2008 jmstar 150cc Chinese scooter ( wife's bike)Comment
Why would you want to dump a "crap ton of fuel into the carbs?"
Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fixComment
These carbs can handle much higher air/fuel volumes than our engines can consume now... even at the 1196 bore. Simply adding fuel would richen things up and run like crap..
Such an item might be useful when using a nitrous boost as the NO2 leans things out rather significantly, other than that, can't think of a reason. have a nice day and ride safe
I am the Lorax, I speak for the Trees
'80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
'79 XS1100 F R (IL Barrachino)
'00 Suzuki Intruder 1400 (La Soccola)
'77 KZ400s (La Putana)Comment
i just fughure maybe at high speeds (90+mph) these bike run lean_____________________________________________ 1979 XS 1100 Special "The judge" mods- K&N air pods, 4-1 mac, 147.5 pilots, 57.5 mains, LED turn signal, cafe bars, HEL translucent yellow stainless steel brake line, dyna coil (dc2-1), raptor 660 mc, r6 controls..(sold)
I've only had mine up to 85 mph
(since that is what the speedo says!!) but I know it tachs about 5k at 70 mph and I have had it tacke dup to about 7500 in 5th gear. If the way it runs there is lean, I'd hate to feel if it was running right!
78 XS750Comment
I would assume that the way the tank is, gravity feed probably can't feed fast enough, so they added a small pump.
Dweebs might call it a 'dump pump'.Nice day, if it doesn't rain...
'05 ST1300
'83 502/502 Monte Carlo for sale/tradeComment
If you were to take the gas tank and set it on a saw horse and the petcock were to be opened up accidentally you would find that the tank would be completely empty in just a couple of minutes DAHIK. There is no way, even at 100+ mph that the engine could handle that much fuel so why add a pump?
If one was to add one I am sure that you would have to redo all of the fuel lines to take the added pressure or you would be looking at leaks for sure.The Old Tamer
1979 XS1100SF (The Fire Dragon)
1982 650 Maxim (The Little Dragon)
another '82 650 Maxim (Parts Dragon)
1981 XS1100SH (The Black Dragon)
If there are more than three bolts holding it on there, it is most likely a very important part!Comment
even if one to put pod on the carb and and supertrapp..... with no rejet... would the engine need more fuel......there wouldnt need to be a rejet whould there... but im going to yamaha tomorrow because i got to pick up airfilter and also because they'r the ones who sold it to him so ill ask them about it..._____________________________________________ 1979 XS 1100 Special "The judge" mods- K&N air pods, 4-1 mac, 147.5 pilots, 57.5 mains, LED turn signal, cafe bars, HEL translucent yellow stainless steel brake line, dyna coil (dc2-1), raptor 660 mc, r6 controls..(sold)
You would have to modify the carbs to allow the fuel to get into the mixture, and it would probably take much more work to get that right than to just rejet the carbs and you would get a much more reliable and consistent mixture (meaning more power) with the rejet.
Aux pumps are generally used with fuel injection to raise the pressure under boost or NOS conditions to push more fuel out the injectors without any other changes.Cy
The term 'dump' pump is usually used to indicate a pump installed to allow the quick removal of fuel form the vehicle.
if your shipping a bike around, say for racing, it is recommended you empty the gas for transport...Nice day, if it doesn't rain...
'05 ST1300
