Ivan, you might look into biltwell. They have a setup where you make your own exhaust. You get however many bends and whatnot. It's for v twins, but they say you can get two exhausts out of them.
Marshall Deeptone Dealer in the US
There is a site http://www.coneeng.com/ that has good prices on collectors and pipes .Thinking about making my own also .My last xs had a Kerker,I liked that pipe .Just need to copy/take measurements from a known power makerComment
Ivan,
I received my order of mandrel bends and exhaust clamps and tried to make something up on Saturday...that's eight hours of my life I'll never get back
I found out two things: 1. trying to figure out those bends requires duct tape to keep my head from exploding, and 2. my el cheapo Harbor Freight welder coupled with my welding skills results in nothing but a bunch of holes burnt through expensive mandrel exhaust tubes
But you are on to something. For someone with the proper equipment and skill to do it, building an exhaust pipe for an XS1100 is quite possible to do. It sure would be great for someone to come up with a 4 into 1 into 2 system with some sexy upswept megaphones
My heros have always been flat trackers.Comment
Harbor freight welders are not good for fine control. I would probably do much better with a torch and a small tip, since I can't float a tig... But then again, its been several years since I did any type of welding, so I would take me quite some time to get the technique back.Ivan,
Ich habe dich nicht gefragt.Comment
What about an X pipe setup??? My only problem would be the super sweet mega awesome upsweeps. The gears in my mind are turning... just got the second gear fixed
im so furnnyAustin Ingalls
MIDNIGHT FURY
1979 XS1100 Special [Full Restore Project]
XJ maxim rear air shocks
KERKER 4-into-1 exhaust
Pod Filters
Money pit.......
BLACKED OUTComment
This is my tranzac exhaust
was thinking of cutting off the collector
where it goes into 1 and putting a 'x' pipe there
for a dual muffler system.
as is this set up pulls harder in the mid range compared to a 4 -1,
but loses a cpl of hp at the top end.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
Here is the Ebay sight for the Campbell X-pipe: http://cgi.ebay.com/ws/eBayISAPI.dll...fvi%3D1&_rdc=1
In my quest for some solution, I actually talked to Monty today on the phone...figure that
If the exhaust performs like claimed...and I don't have reason to doubt...it would make a great performance pipe. However, it is expensive and I'm not sure it will provide the look I want. The canister doesn't exit much past the front side of the rear tire...probably about where the rear pegs are located. That might be uncomfortable for a rear passenger.
A chrome system is probably around $700 to $800 by my estimations
Please keep in mind that is my estimate and not a quoted price.
Pete,
What are you guys overseas using for replacement exhausts?
From what I read, the 4 into 1's are not the best performing systems for our bikes. The 2 into 2 and 4 into 1 into 2's are the better performers.My heros have always been flat trackers.Comment
Mashermoto,
Didnt you have a set of kerker head pipes
fitted on your bike, there a quality headpipe.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
I was going to ask if anyone had done a 4-2-1 .have you run that pipeComment
yep, got it on atm,
it pulls harder from 3000 onwards
than a 4 - 1, (ive got 2 different types of 4 -1 headers )
but not as hard as a 4-1 after 6000rpm onwards.
The sound is different to, sounds a bit tinny,
i prefer the sound of the 4-1, but i like the mid range performance
of the 4-2-1.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
Mash,
From what ive been reading lately, as far as after market exhausts,
the guys here are using the tranzac exhaust, (the 1 in the pic)
they are an aussie company in queensland
(i think from memory this is the
same exhaust aussiexs11g uses, he got over 100hp on a dyno
with his engine mods.
Other than that, ive got the marshall 4 - 1 headers
and another aftermarket 4-1 header that i dont know the make.
From what i know tho if you can get hold of an original 4 -2 stock
exhaust, they are the best systems for our bikes.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
