I didn't pull the H clip yet tonight, I may get bored and do it still yet. If not first thing in the morning. I got distracted installing new progressive springs in my forks. I did take a few pictures, should I throw together a tech tip on the installation process? (it was a lot easier than I thought.
Rattling front brakes
Draft Drawing
Okay, 1st draft drawing of a retainer clip.
Needs further work and dimensions but it's a start. Will do detailled plan and a cutting template as well.
Critique and suggestions please..1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
Brian - I'm impressed! That drawing even has perspective. Devlish clever these cad programs
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
Some dimensions...
Haven't had much time to devote to this in recent days, but here are some updated basic drawings with measurements. Sorry guy's they're in metric, we went metric years ago and these are japanese bikes we're talking about. If I get a chance over the weekend, I'll do a 3D render of the clip and make it look like it was done by someone who knows what they're doing.
Have'nt made one yet so not sure of fit. Measurements were obtained by converting supplied imperial sizes. Will adjust and update as and if required to make it fit.Last edited by b.walker5; 04-28-2009, 03:43 AM.1980 SG. (Sold - waiting on replacement)
Brian - I'm impressed! Nicely done drawing.I think I have a loose screw behind the handlebars.
not complaining or nit picking or anything, but. . . . when giving/getting dimensions for sheet metal that will be broke (bent on a brake) aren't you supposed to add half of the thickness of the material? When i worked in a sheet metal factory i'm pretty sure that's the "formula" we used. For example: The material is .048" thick, you want a flange that is .5" long, don't you start your brake at .524" from the raw edge? (sorry about the imperial dimensions, but it's just for a "what if" scenerio) I didn't do the conversions from metric to imperial from the dimensions you've given, if you've already taken the length eaten up in the bends I apologize.1980 XS11SG
Dunlop elite 3's, progressive fork springs, tkat brace
Stock motor, airbox, carbs, exhaust
ratted out, mean, and nastyComment
Ha...., someone that knows. You are absolutely correct and tolerances will be added to final drawings. These are just the basic drafts from which i'll build one clip to see what, if anything, needs changed and then update the drawings accordingly. Good spottingnot complaining or nit picking or anything, but. . . . when giving/getting dimensions for sheet metal that will be broke (bent on a brake) aren't you supposed to add half of the thickness of the material? When i worked in a sheet metal factory i'm pretty sure that's the "formula" we used. For example: The material is .048" thick, you want a flange that is .5" long, don't you start your brake at .524" from the raw edge? (sorry about the imperial dimensions, but it's just for a "what if" scenerio) I didn't do the conversions from metric to imperial from the dimensions you've given, if you've already taken the length eaten up in the bends I apologize.
What, nobody volunteering to take a perfectly good one and pound it out flat so we can be sure?
Ken TalbotComment
Ken - lol, that was funny.I think I have a loose screw behind the handlebars.
Hi Tim,
Check with http://www.partsnmore.com/parts/yamaha/xs1100/?filters[category]=chassis#product-99-5000
for the Brake Pads. The last set I bought came with those clips. Send them an email asking if the pads still include the clips.
Or check with your local aftermarket parts store.
I doubt you will find the clips only for less $$ than a set of pads from above vendor.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
There's currently a used one on e-bay:
$17.49
Partzilla shows the part interchanges with the bike they have listed on e-bay:
http://www.partzilla.com/parts/detai...849-01-00.html82J · 81SH · 79SF Fire Damage · 78E · 79F Parts Bike · 04 Buell Blast
Website/Blog
