Steering Bearing Replacement
  • gene
    • Mar 2009
    • 267
    • Weston, Fla.
    Has anyone changed out the inner race when changing the bearings? My inner race has flat spots.
    Gene (Florida)
    1980 XS1100SG
    Accel Coils
    4-1 Jardine Exhaust
    • 8870
    Yes, the races must be changed if they have flat spots. They're a bit tricky to get out. If you first clean the grease out of the steering stem, you can look down in there and see 2 access points where a tool such as a drift will fit in against the race. Drive them out from these points. It's a bit tricky to get the right angle, so have patience.
    • John
      • 5117
      Only the upper race land has the notches in it. You will have to make them yourself on the lower race, once you have the race out.
        • 8870
        Shoot, I coulda' sworn there were lower ones too. I did 2 of them not too long ago. Do you use any lock-tite on the outer side of the race when installing the new ones so they don't rock?
